For some reason I get an error message 30 while loading a project in Scene 5.4.2
Does anybody know why and what I can do about it?
I've got 60 GB free disk space and deleted the last two revisions. That didn't work.
Thanks!
Bas
Oh, btw I found a tool called "Faro Scene Error Code 30 repair tool" on a site called saetechnologies
This doesn't look very safe to me. Does anyone have more info about this tool?
Error message 30 in scene
- Leap3D
- I have made 80-90 posts
- Full Name: Bas Notenboom
- Company Details: Leap3D
- Country: Netherlands
- jcoco3
- Full Name: Jonathan Coco
- Company Details: Consultant
- Has thanked: 70 times
- Been thanked: 157 times
Re: Error message 30 in scene
Sounds fishy to me.Oh, btw I found a tool called "Faro Scene Error Code 30 repair tool" on a site called saetechnologies
As far as that error goes...you may find the answer in this thread:
http://www.laserscanningforum.com/forum ... =44&t=8436
- Leap3D
Thanks Jonathan,
I'll put all the fls files into the second last revision folder and let you know if it worked.
Bas
Bas
- jcoco3
I am happy for you
Thanks for sharing your success, it helps confirm that correcting the directories can salvage the project.
- 1
- Full Name: Justin Wetterberg
- Company Details: Rörkraft
- Company Position Title: Documentalist
- Country: Sweden
- Has thanked: 10 times
If this is considering to necro a post feel free to delete my response, admins.
I found this thread after running into this error in Scene 2022.0 and 2022.1 so I thought I'd update in case someone else runs in to it and find this thread.
I had a project that I wanted to import to an other larger project and after saving and opening the larger project I got this error.
There was 5 scans in the larger project with a ? next to them and those five seemed to be the problem.
After some troubleshooting I noticed that those 5 scans had been present in both the projects, although with different names.
After I deleted them in the larger project and imported the small one again everything worked as it should again, so if you run in to this, make sure that there isn't any duplicate scans anywhere.
When we've imported a project in to a project and there's been duplicate scans before they have had the same name and Scene has overwritten the old ones in order to fit in the new ones. The reason we had a hard time finding the duplicates this time was that they had different names, but they had the exact same points/images etc in both projects. I think that I had exported those 5 scans as E57 a while ago and imported them, hence the different naming.
