Circle (lisp) routine in autocad
- I have made 90-100 posts
- Full Name: Cornelis Kolbeek
- Company Details: 3dszkennelés
- Company Position Title: Scan specialist
- Country: Netherlands-Hungary
Hey guys,
I'm looking for a circle routine that computes a circle through several points.
Here's the twist though: I need the circle to have a certain diameter/radius.
Preferably I'd like the routine to compute the circle, and give me an deviation towards the radius per point.
Kind regards,
CK
Kind regards,
CK
- Honorary Member
- Full Name: Matthew McCarter
- Company Details: Costain
- Country: England
- Has thanked: 5 times
- Been thanked: 4 times
Re: Circle (lisp) routine in autocad
I know it's not quite what you are looking for, but it is not uncommon in the rail industry (I'm assuming tunneling as well) to require a circularity check on a profile of a tunnel.
We wrote an internal macro for Excel to do this based upon data exported from our mobile scanning systems.
I wouldnt be suprised if a similar macro is not available to download somewhere online.
- Full Name: Gareth Edwards
- Company Details: Cadplan
Not sure I fully understand. Am I right that you want to input a radius or diameter of a circle, then pick a number of points on the screen (or inputed) and then get a best fit for a drawn circle?
Cadplan
Cadplan
Correct,
Right now I use the attached routine.
But for example with flanges, they are machined, so the radius is quite precise.
Therefore I want to eliminate the deviation, created either by the surveyor or total station, by telling Autocad what radius it should be.
Cheers!
Cheers!
I think I see what you are trying to achieve and a routine can be made to pick all the points and to draw a circle of a certain radius/diameter. The difficulty it seems to me might be how to position the circle to create the best fit with the points.
- Phill
- Full Name: Phillip Nixon
- Company Details: SKM
- Has thanked: 7 times
- Been thanked: 45 times
CK
See attached. BTW least squares really messes with my brain. Please dont ask for this in 3d, I have no idea how those Cyclone gurus do a fit to cloud cyclinder. I have attached the pdf I based the calcs on and my answer matches the example data. I have got the lisp to calc the center of a nominal circle to fit the points but made the text differences from the user inputed radius (the calced best fit radius is printed as Nominal radius on the command prompt). I am assuming that the center of a best fit circle would be the same as if it were fitting a given radius to the points.
Hope this is what you were looking for. If it's useful you owe me a beer or two. If you edit it to make it better, repost so others can use it as well.
Phill
Phill
Hey Phill, thanks!
I'm in the field right now so I can't check it out.
I think by now I owe you a crate already.
Cheers!
CK
Cheers!
CK
- FritjofS
- Full Name: Fritjof Andre Skaar
- Company Details: Anko AS
- Country: Norway
- Skype Name: fritjofskaar
If you get your hands on the old Leica program calles AXYZ, you can calculate circles with a given radius. I always use this program when measuring spools and flanges. This program also include many other types of geometry calculation.
- Full Name: Andrew Softley
- Company Details: Laing ORourke
- Company Position Title: Project Land Surveyor
Thanks Phil. This is very useful. I had a similar least squares routine that I somehow lost.
I've tweaked it slightly to draw the best-fit circle using the design radius and also output to 4dp, as that suits how I work. As it may be of use to others, here it is:
Code: Select all
(PRINC "\nFit circle to points Version 1.0, type FC2P to run")
(DEFUN C:FC2P ( / )
(SETQ aws (SSGET '((0 . "POINT"))))
(SETQ POINTLIST NIL)
(SETQ COUNT 0)
;CREATE POINT LIST
(REPEAT (SSLENGTH aws)
(SETQ P1 (CDR(ASSOC 10 (ENTGET (SSNAME aws COUNT)))))
(SETQ P1 (TRANS P1 1 0))
(SETQ POINTLIST (APPEND POINTLIST P1))
(SETQ COUNT (+ COUNT 1))
); ende repeat
;GET SUM AND AVERAGE FOR U,V VALUES
(SETQ SUMX 0)
(SETQ SUMY 0)
(SETQ COUNT 0)
(SETQ N (/ (LENGTH POINTLIST) 3))
(REPEAT N
(SETQ X (NTH COUNT POINTLIST))
(SETQ Y (NTH COUNT POINTLIST))
(SETQ SUMX (+ SUMX X))
(SETQ SUMY (+ SUMY Y))
(SETQ AVGX (/ SUMX N))
(SETQ AVGY (/ SUMY N))
;CREATE UVLIST WITH MULTIPLES AND SUMS
(SETQ UVLIST NIL)
(SETQ SUU 0
SVV 0
SUV 0
SUUU 0
SVVV 0
SUVV 0
SVUU 0
(SETQ COUNT 0)
(REPEAT N
(SETQ U (- (NTH COUNT POINTLIST) AVGX))
(SETQ V (- (NTH COUNT POINTLIST) AVGY))
(SETQ UU (* U U))
(SETQ VV (* V V))
(SETQ UV (* U V))
(SETQ UUU (* U U U))
(SETQ VVV (* V V V))
(SETQ UVV (* U V V))
(SETQ VUU (* V U U))
(SETQ SUU (+ SUU UU))
(SETQ SVV (+ SVV VV))
(SETQ SUV (+ SUV UV))
(SETQ SUUU (+ SUUU UUU))
(SETQ SVVV (+ SVVV VVV))
(SETQ SUVV (+ SUVV UVV))
(SETQ SVUU (+ SVUU VUU))
;CREATE A MATRIX
(SETQ A11 SUU)
(SETQ A12 SUV)
(SETQ A21 SUV)
(SETQ A22 SVV)
;CREATE B MATRIX
(SETQ B1 (/ (+ SUUU SUVV) 2))
(SETQ B2 (/ (+ SVVV SVUU) 2))
;CREATE ATA
(SETQ ATA11 (+ (* A11 A11) ( * A12 A21)))
(SETQ ATA12 (+ (* A11 A12) ( * A12 A22)))
(SETQ ATA21 (+ (* A21 A11) ( * A22 A21)))
(SETQ ATA22 (+ (* A21 A12) ( * A22 A22)))
;DETERMINE DETERMINANT
(SETQ DET (- (* ATA11 ATA22) (* ATA12 ATA21)))
(SETQ DET (/ 1 DET))
(SETQ INV11 (* -1 ( * DET ATA22)))
(SETQ INV12 (* -1(* (* DET ATA12) -1)))
(SETQ INV21 (* -1(* (* DET ATA21) -1)))
(SETQ INV22 (* -1(* DET ATA11)))
;CREATE ATB
(SETQ ATB1 (+ (* A11 B1) (* A12 B2)))
(SETQ ATB2 (+ (* A21 B1) (* A22 B2)))
;CREATE X
(SETQ X1 (+ (* INV11 ATB1) (* INV12 ATB2)))
(SETQ X2 (+ (* INV21 ATB1) (* INV22 ATB2)))
(SETQ CX (+ (* X1 -1) AVGX))
(SETQ CY (+ (* X2 -1) AVGY))
(COMMAND "POINT" (LIST CX CY))
(SETQ NRAD (SQRT (+ (* X1 X1) (* X2 X2) (/ (+ SUU SVV) N))))
(PRINC (STRCAT "\nNominal Radius " (RTOS NRAD 2 4)))
(SETQ RAD (GETREAL "\nDesign Radius: "))
(COMMAND "CIRCLE" (LIST CX CY) RAD)
(SETQ COUNT 0)
(SETQ DIFF (- RAD (DISTANCE P1 (LIST CX CY))))
(COMMAND "TEXT" P1 "0.025" "90" (RTOS DIFF 2 4))
); ende repeat
- Full Name: Dobromir Balla
- Company Details: Software development
- Company Position Title: Geodesist-Software Developer
- Country: Bulgaria
If you have Civil 3D you can use menu: Lines/Curves > Create Best Fit Entities > Create Arc
