pictures to pointcloud
aurivus|REVIT, 3D Studio MAX, 3D Coat, Lightwave, ZBrush, VRMesh, TopoGun, Blender, Rhino, Trimble Sketchup Etc.
jdg072
Full Name: Johan
Company Details: Pantarein
Company Position Title: CAD
Skype Name: jdg072
Has thanked: 6 times
Post by jdg072 »
What software is popular and payable to convert +- 80 (drone) pictures into a pointcloud where I can measure?
This forum must know a good way to do it, right?
BR, Johan
mariusP
11
Full Name: Marius Putrimas
Company Details: Terra Modus
Company Position Title: Undet product manager
Country: Lithuania
Has thanked: 29 times
Been thanked: 39 times
Re: pictures to pointcloud
Post by mariusP »
jdg072 wrote: Fri Nov 17, 2023 12:11 pm What software is popular and payable to convert +- 80 (drone) pictures into a pointcloud where I can measure?
BR, Johan
Hi Johan,
https://www.capturingreality.com/ - you can try this software. You will only have to pay when you are satisfied with the final result. The export price is very good.
We are developers of Undet Software
UNDET specializes in software solutions for point cloud modelling, our mission is to streamline daily operations, boost productivity, and minimize manual effort in delivering 3D models and 2D drawings.
www.undet.com
jdg072
Full Name: Johan
Skype Name: jdg072
Post by jdg072 »
Many thanks
VXGrid
7
Full Name: Martin Graner
Has thanked: 158 times
Been thanked: 171 times
Post by VXGrid »
BR, Johan
To name some more:
- dji terra
- pix4d
- agisoft metashape
With only pictures, you are not able to create a point cloud in which you can measure (at least not with a fixed unit, you get the result in pixel/image space, not world space).
Photogrammetry has no scale, so you need to have either really good position information, where the picture was taken (GPS), or you have something in the images to calculate the correct scale (measured points)
Martin_au
14
Full Name: Martin Ankor
Company Details: Anon
Been thanked: 23 times
Post by Martin_au »
Also webodm.
jdg072
Full Name: Johan
Skype Name: jdg072
Post by jdg072 »
VXGrid wrote: Fri Nov 17, 2023 7:11 pm With only pictures, you are not able to create a point cloud in which you can measure (at least not with a fixed unit, you get the result in pixel/image space, not world space).
What do all these softwares create then instead of pointclouds?
I should be able to scale the result to a correct scale If I take 1 or 2 measurements on site to verify, right?
Also found nira.app
ScottErnst
I have made 90-100 posts
7
Full Name: Scott Ernst
Company Details: Southwest Scanning
Company Position Title: owner
Has thanked: 3 times
Been thanked: 12 times
Post by ScottErnst »
Photogrammetry can create both meshes and point clouds. Yes, if you have some known measurements you can create scaled models. If you are taking the photos with a drone, the GPS will give scale that is pretty good. Providing the software with known measurements will give you more accuracy.
I use Bentley's iTwin Capture (formerly ContextCapture). They claim an accuracy of 3x the size of the pixel on the object that you are photographing. If you are shooting with, let's say, a 20mp sensor from 100' you get a pixel on the ground that is about .5". If you are shooting with a 42mp sensor from 20' the pixel on the object is super small.
sim.herrod
8
Full Name: Simeon Herrod
Has thanked: 73 times
Been thanked: 109 times
Post by sim.herrod »
jdg072 wrote: Sat Nov 18, 2023 9:02 am I should be able to scale the result to a correct scale If I take 1 or 2 measurements on site to verify, right?
Use a proper scale, not just a tape or disto if you want to do things 'properly'.
We use these for smaller photogrammetry jobs...https://pasthorizons.com/products/photo ... eq=uniform
For larger jobs, we would use TS survey control with GCPs and/or April Tags.
jdg072
Full Name: Johan
Skype Name: jdg072
Post by jdg072 »
ScottErnst wrote: Sat Nov 18, 2023 2:53 pm If you are shooting with, let's say, a 20mp sensor from 100' you get a pixel on the ground that is about .5". If you are shooting with a 42mp sensor from 20' the pixel on the object is super small.
I plan to use a drone:
https://www.dji.com/be/mini-4-pro
Fly about 10 meters above ground
Return to “Modeling Software”
