Hello
I have a bundle that spans 2 sitemaps (one ofr each floor). I want to export each sitemap for each cloudpoint file (rcp/e57).
The publish aalways ends up creating one file with both sitemaps merged into one single point cloud. I'm not seeing how I can export a point cloud for ach sitemap. Can you help me in this matter?
Export cloudpoint by sitemap
- Full Name: Hugo Silva
- Company Details: TopoRigor
- Company Position Title: Engenheiro Geógrafo
- Country: Portugal
- geomontgomery
- Company Details: ECE Design
- Has thanked: 20 times
- Been thanked: 48 times
Re: Export cloudpoint by sitemap
When you "Finalize", look in the upper left hand side. There should be checkboxes by each sitemap, where you get to choose which one you publish.
- Country: Portugal
Thank you for your quick response.
Yes I already checked them both, but then when I publish there is no way to "split" the export in two seperate cloudpoint file.
So, you say that I need to make a publish for each one? I select one sitemap in the finalize, then publish. After publishing the first cloud i then have to go again to finalize section, select the other sitemap and then publish it?
What I was trying to do is to do that in one publish...
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 51 times
- Been thanked: 297 times
You could export separated setups then do the merging however you want. Recently i implemented exactly the same functionality to our subsampler merger program based on pdal.
- Country: Portugal
- Country: Hungary
During export you can select export structured separated e57 files. So every setup will be a new e57. If you open those for example in cloud compare you can merge them however you want. Let say you open every setup on the first sitemap then you can merge them inside cloud compare subsample then save.
- Full Name: Tristan Thibault
- Company Details: BBA
- Company Position Title: Coordonnateur en technologies relevés 3D
- Been thanked: 5 times
I have been asking Leica to be able to export multiple site map as multiple file. I know it is pain in the a.. when you split projet and want to have multiple file. We where working on a big projet and need to export 38 individual site map... You need to do it one by one
