Leica Cyclone FIELD 360 v4.1.0
- LeicaUK_RC
- Full Name: Phil Marsh
- Skype Name: Phil.H.Marsh
- Been thanked: 52 times
A new update is now available which features loop closure and optimisation of bundles plus you can directly export whilst in the field…
- Full Name: Chris Widmer
- Company Details: KCI
- Company Position Title: 3D Scanning Manager
- Has thanked: 3 times
- Been thanked: 8 times
Re: Leica Cyclone FIELD 360 v4.1.0
Thanks for the heads up, we are going to update and check it out.
- Full Name: Gavin Foster
- Company Details: Offset Services Ltd
- Company Position Title: Photogrammetry - Laser Scan
- Has thanked: 4 times
- Been thanked: 3 times
Has something changed with the license requirements here as I've just updated my IPad and now get and error when trying to pair a device.
Error message reads 'Scanner not available due to license incompatibilty'
Gav
Gav
- I have made 80-90 posts
- Full Name: Patrick
- Company Details: 360G
- Country: uk
- Has thanked: 10 times
- Been thanked: 14 times
Does this update allow RTC360 full resolution scans to be exported direct from Field 360 as E57 files?
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 52 times
- Been thanked: 297 times
After the first few hours and the field crew told us it is slower then before. We don't need e57export nor bundle optimalization in the field it never gonna replace office work.
- Kruse
- Full Name: Eric Kruse
- Has thanked: 77 times
- Been thanked: 205 times
Out of curiosity, is there a tablet Leica recommends (iOS or Android)?? Latest gen iPad Pro or Samsung tablet? Maybe something else all together? With the new features of optimization and loop closures, I'm assuming that'll take more CPU/RAM horsepower, so I'm just curious if there's a definitive best tablet.
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 767 times
- Been thanked: 149 times
You may have to re-put your EID in (For REg 360 or Cyclone REg. I've had to do that before with that app,) Is your CCP up to date?
- Full Name: simon dealtrey
- Company Details: Flo-Mech Limited
- Company Position Title: Flo-Mech Limited
- Country: United Kingdom
We had an issue yesterday whereby you could not connect to the RTC scanner - Workaround from tech support is to remove EID in your CLM and also in the cyclone cloud portal and then re-add. This allowed the scanner to be selected as normal in the field app. Tech support are following up on the problem. When I hear back I can update.
Seems the fix to this one as a few of you have mentioned is to remove the EID from the Cyclone Cloud Portal then add it back , log out of the field 360 app then back in.
Up and running again now.
Gav
- Has thanked: 9 times
- Been thanked: 20 times
Hi All,
Can anyone confirm that you can import control files and perform resections etc with a P40?
Or is it limited to visual alignment?
Thanks,
Chris
Thanks,
Chris
