Hello All,
I have the Surphaser 25HSX, which is an 11kg behemoth.
I see that EZ jib was quite popular, but it seems it is not in production anymore.
The Pro-Aim Kite 22 seems to have a good balance between payload, reach, assembly time and cost. However, it doesn't have a parallel arm to lock the camera tilt, a wire is used. I'm unsure of the crane's stability while scanning and whether a mast would be a better solution by trading more reach for stability. Pro-Aim Wave 10'Ft seems to be the ideal solution, but it's 2m reach from the pivot point is not worth it.
https://www.bhphotovideo.com/c/product/ ... ge.html/qa
Appreciate it if you could share your experience.
Jib Crane for Heavy Scanner
- I have made 30-40 posts
- Full Name: Akram Mousa
- Company Details: ReCreate3D
- Country: UAE
- Has thanked: 3 times
- Been thanked: 3 times
- Full Name: Ioannis Papas
- Company Position Title: CEO
- Country: EU
- Skype Name: -
- Has thanked: 99 times
- Been thanked: 62 times
Re: Jib Crane for Heavy Scanner
If it possible test it before buy it you will have problems with vibrations in scans I think.
- Country: UAE
Will need to buy overseas. I don't have a chance to test. Maybe a 6m mast can be a better option.
- Country: EU
- Skype Name: -
I have 6meters from fireco Italian company, scanner has vibrations at 6m.
If you want to mount it needs ropes to stabilise it complicated.
- Peyman Bashiri
- Full Name: Peyman Bashiri
- Skype Name: pbashiri2003
- Has thanked: 56 times
- Been thanked: 40 times
- 1
- Full Name: Mahi Sheth
- Company Details: Ambica Engineering Co
- Country: India
Ambica Engineering Co. is one of the most reliable jib crane manufacturer and suppliers. We are capable of supplying jib cranes that can handle a load of up to 6 tons& 6 mtr. Being one of the leading jib crane, we promise superior quality cranes with cantilever boom rotation, giving the option to rotate crane from 180 to 360 degree.
Contact: https://www.ambicaengineering.com/jib-crane/
- Scott.Warren
- Full Name: Scott Warren
- Company Details: WSP Canada
- Has thanked: 44 times
- Been thanked: 111 times
6 ton load for a 50lbs scanner seems excessive.
Would be nice though.
