Faro Premium scanner data exporting problem to SD
- Full Name: Renalds Steinbergs
- Company Details: Efekta
- Country: Latvia
- Has thanked: 9 times
Hello everyone!
I have trouble with new Faro Premium scanner exporting data from internal memory to memory card. I tried everything I can find:
Formatted sd card;
Used transfer button - nothing..
In setting options - storage management - using little sd card icon transfer button.. it shows that data is transferring but after few seconds it says that scan transferred is finished but memory card is empty.. and at the storage management scan count is 0, but in project/cluster map initial scan number is 65..
One more solution would be try with another sd card but at the moment I don't have it, although sd card that I use is original card that came with scanner.
Fully hope that some of you have some ideas what can I do!
Thank you already
Formatted sd card;
Thank you already
- Country: Latvia
Re: Faro Premium scanner data exporting problem to SD
Manage - Projects/clusters - selected project that I want to export - go back to home screen - sd card icon?
Yes I tried, shows that scans and data are being copied to the sd card and after 5 sec appeared following massage - Exported the selected projects successfully to the SD card, but sd card is empty, except:
Is-data map;
Scans map (empty)
FARO-LS file
index-v2 file
ScannerDataCard file... nothing more
Is-data map;
Scans map (empty)
FARO-LS file
index-v2 file
- I have made 80-90 posts
- Full Name: Emanuele Ferrari
- Company Details: Studio FERRARI
- Company Position Title: Titolare
- Country: Italia
- Been thanked: 15 times
I didn't have this problem.
Has the card been formatted in the scanner or on a pc?
- Country: Latvia
Yes, sd card was formated both in pc and scanner.
I guess have no other option then try with another sd card.
Thank you for response, I will send update how it go's with new sd card.
Have a great day!
Have a great day!
- Justin Richards
- Full Name: JUSTIN RICHARDS
- Has thanked: 38 times
- Been thanked: 51 times
With the premium, sometimes you just need to restart the scanner.
If nothing else, contact Faro support. It is possible to access it like a drive after changing some settings in the scanner.
- Country: Latvia
Thank you for replying Justin, but in this situation restarting also don't work.
I tried with new sd card still no success, but I contacted Faro support and they suggested connecting to the scanner via WLAN so I waiting for our company tech guy and hopefully this will allow to access data.
- 1
- Full Name: chandan yeshwanth
- Company Details: TU Munich
- Company Position Title: PhD
@SDlaner were you able to solve this? We have the same issue with our scanner - it shows "0 MB Scans: 0" for all scans when the scanner is restarted and they can never be exported, so it only works when we export the scans to SD card right before shutting down the scanner.
The other option is to scan directly into the SD card (Storage Management -> select SD Card), but then it doesn't list the scans/projects there, only shows up when we insert the SD card in the PC. Have you encountered anything like this?
- Full Name: Andrew Bassett
- Company Details: Glanville Consultants
- Company Position Title: Principal Land Survey
@meowgoldie, we are also getting the issue,0mb 0 scans within each project if the internal hard drive is used to record the scans.
We have also tried using Faro Steam to see the scans, still nothing.
The data is on hard drive ad we can see the amount is scans when interrogating the internal hard drive.
We have contacted Faro UK tech for support and they can replicate the issue, so this has been escalated high up within Faro Europe.
So hopefully we will have a solution soon.
- Country: Latvia
After contacting Faro Europe solution was just format internal memory that mean we had to delete all data to repare scanner. After that there was no problem any more, but as I said, we had to redo all our projects that was on scanner.
Lesson from this situation - format your sd cards and internal memory as often as you can after copying all scans.
