Hi, I'm running a older tx5 and it would be nice to have every scan set at 0,0,0 in the scans. Any way this is possible?
Or a batch run to set the transformation position in scene all at 0,0,0 in 1 go?
Set scan coordinates to 0,0,0
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
- Full Name: Sebastian Winkler
- Company Details: INVERS Industrievermessung und Systeme
- Has thanked: 5 times
- Been thanked: 6 times
Re: Set scan coordinates to 0,0,0
Hi Lieven,
you just need to switch off all sensors (except inclinometer) under Scan Parameters. I don´t think that there is any way to batch process this inside SCENE.
Regards Sebastian
Regards Sebastian
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
Scantaxi transformation remover?
You can decide to delete inclinometer too, optionally.
Free, by the way..
https://www.scantaxi.de/software.html
Free, by the way..
- landmeterbeuckx
- Country: Belgium
Thanks Massimo,max72 wrote: ↑Thu Apr 28, 2022 8:42 pm Scantaxi transformation remover?
Free, by the way..
I've installed and asked for a reg code. Do you run other Scantaxi apps as well?
- Country: Italy
I use the coordinate exporter. I use it to "send" targets or reference points to Scantra, using a couple of scripts.landmeterbeuckx wrote: ↑Fri Apr 29, 2022 6:59 amThanks Massimo,max72 wrote: ↑Thu Apr 28, 2022 8:42 pm Scantaxi transformation remover?
Free, by the way..
- Full Name: Warren Wilford
- Company Details: Berkshire Dimensions
- Been thanked: 17 times
If you do not register on the initial import of the scans will they stay at 0,0,0?
