Hi there,
I get this black star / lines in the top of my realview when exporting in E57, PTX from Cyclone to Recap. Same star appears in Scene, but in white.
Any ideas why am I getting this ?
Black lines / star in realview from Cyclone to Recap.
- Full Name: Iga
- Company Details: Nothing
- Company Position Title: Nothing
- Country: Greece
- Full Name: Tristan Thibault
- Company Details: BBA
- Company Position Title: Coordonnateur en technologies relevés 3D
- Been thanked: 5 times
Re: Black lines / star in realview from Cyclone to Recap.
this could be dust/steam that got scan over you scanner then Reg360 remove it ( import filter, clean up, moving detection, etc) and then when you import it in recap, Recap create picture from the point cloud. If some point where delete, Recap will put black in the picture.
Last edited by tristanthibault on Tue Apr 19, 2022 2:59 pm, edited 1 time in total.
- Full Name: Iga
- Country: Greece
The cube images do not show it. They 're perfect clean.
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 52 times
- Been thanked: 297 times
It is a known issue recap does not uses the cubemap images, it uses the pointclouds to generate images, there will always be black lines in recap imagery if you import e57, ptx, other structued data format except fls. You can only get the images in recap, from cyclone products if you export recap straight from cyclone. And you follow a specific procedure. There are topics about that, but it requires publisher prro license.
- Full Name: Iga
- Country: Greece
Thank you for your answer, I will look it up !
- 1
- Full Name: Fras Roman
- Company Details: POLYUS
- Company Position Title: engineer
- Country: RUSSIA
В продолжении данной темы. Кто-то может подсказать как выставить в Register 360 область фильтрации при импорте меньше 1 метра? Т.к. зачастую станции находятся в узких проемах и при фильтрации в 1 метр часть поверхностей удаляется.
- jcoco3
- Full Name: Jonathan Coco
- Company Details: Consultant
- Has thanked: 70 times
- Been thanked: 157 times
Google Translated:
In continuation of this topic. Can someone tell me how to set the filtering area in Register 360 when importing less than 1 meter? Because Stations are often located in narrow openings, and when filtering 1 meter, part of the surfaces is removed.
