Hello all,
I have an intermittent problem with a Faro Focus 3D X130 scanner. Sometimes the scanner will perform a 720 degree scan instead of a 360deg scan. See attached preview. If i import the scan into recap it will compress it to 360deg and the scan is useless. Does anyone know why this is happening and how to solve it? annoyingly, resetting the scanner only solves the problem sometimes. i have no definitive way of resetting it.
Rich
Problem = 720 degree scans?!
- Full Name: Attewell
- Company Details: Greenbank
- Company Position Title: Greenbank
- Country: United Kingdom
Re: Problem = 720 degree scans?!
in the image above you can see its done a 360deg horizontal scan (whilst rotating 180deg) and then its done another 360 deg horizontal scan (whilst rotating 180deg)
so in total its done a 720 deg horizontal scan whilst rotating 360 degs.
Does anyone have any ideas or solutions?!
- I have made 80-90 posts
- Full Name: Emanuele Ferrari
- Company Details: Studio FERRARI
- Company Position Title: Titolare
- Country: Italia
- Has thanked: 9 times
- Been thanked: 15 times
I have an X330 and a similar "effect" happened to me in rooms with several mirrors on the walls.
The images seem extracted from Recap, even in Scene there is this error?
- Leandre Robitaille
- Company Details: Cima+
- Has thanked: 61 times
- Been thanked: 246 times
Firmware is up to date. it was serviced a coupe of months ago.
The problem is happening during scanning. the photo preview is the direct scanner preview jpg. Ive tried importing them but the scan is fudged.
i did manage to get it to correct itself by changing the horizontal scan area from 0 -360 to 1-359. this worked first time. but i tried later in the day and it didnt work.
My current workflow in an attempt to get it working is:
try shortest scan (indoor under 10m, colour off, under 2 mins)
format SD card in scanner
reset to factory setting.
check date and time
turn on all sensors
restart scanner
ensure level
swap SD card
swap battery
try plugged in
check operating temperature
AND REPEAT!
check date and time
turn on all sensors
restart scanner
ensure level
swap SD card
swap battery
try plugged in
AND REPEAT!
- Full Name: Martin Graner
- Has thanked: 160 times
- Been thanked: 175 times
I don't have the FARO options in my head currently but one parameter should be 0->360 while the other is 0->180 ° right?teggs wrote: ↑Thu Dec 16, 2021 9:38 am Firmware is up to date. it was serviced a coupe of months ago.
Is it possible that these two got switched or something, or are set incorrectly?
What is your vertical scan area?
This sounds honestly more like a thing FARO directly can help you with....
