Hello, when i import a tdx file into Realworks rwi and then export to a Recap file, i can only see the scanned pointcloud, but not the photos / images. I am in doubt if i use the right workflow for this.
I assume it is possible to export to Recap including the photos / images?
Does someone know how to do this?
regards, Jan
Trimble Realworks to Recap, no images
- Full Name: Jan Harink
- Company Details: TSpD BV
- Company Position Title: TSpD BV
- Country: Nederland
- blazaj
- Full Name: Jiri Blazek
- Country: Czech Republic
- Has thanked: 45 times
- Been thanked: 18 times
Re: Trimble Realworks to Recap, no images
Hi Jan,
you need to convert TZF scans in Registration mode rather than export in Production mode. Select group of scans or all proiject and go to Export - Convert TZF scans. It works with E57 output, I guess it should work wit RCP as well
Regards
Jiri
Regards
Jiri
Hi Jiri,
i have tried converting TZF to RCP. I get the complete Support folder, but the RCP file is missing.
regards, Jan
regards, Jan
- blazaj
I see. Can't help you with that. Try export couple of E57's this way and import into Recap to see if bubble views are created.
- I have made 50-60 posts
- Full Name: Jason Hayes
- Company Details: Trimble
- Company Position Title: Product Manager 3D Scanning Software
This is very strange for the RCP to be missing. Without having all the details I would suggest using the convert to E57 and then bring those into Recap and let it convert to RCP and see if that helps.
Hello, exporting to E57 and import in Recap does it. Thanks.
regards, Jan
regards, Jan
