ok guys im getting tired of having to clean up the point cloud with every scan from these parasite points coming from the top of the scanner whats can i do to fix this issue?
The lense looks clean to me.
X7 PARASITE POINTS
- Full Name: Dustin J sirman
- Company Details: Cam Integrated Solutions
- Company Position Title: 3D Survey Lead
- Has thanked: 4 times
- Been thanked: 5 times
X7 PARASITE POINTS
- Full Name: Jared
- Skype Name: jaredmatthews
- Has thanked: 5 times
- Been thanked: 13 times
Re: X7 PARASITE POINTS
Does this happen on every scan? And on various other projects? or just this site?
I see a bit of Dirt track... Not to make any assumptions, but could it be dust particles being picked up?
Good thinking on cleaning the lense. Does it just "look" clean, or have you actually tried cleaning it with an alcohol wipe? (sometimes there could be oiliy smudges that may not be obvious to the naked eye)
- Leandre Robitaille
- Company Details: Cima+
- Has thanked: 61 times
- Been thanked: 246 times
Those happen on most scanners but they get filtered out. You could try the medium filtering when doing your recap import. I am not sure for TBC or what ever software you are using (if any) but to filter those with a faro scanner we would use "stray point filter".
Maybe my post will inspire someone more in the know towards the filter you should be using with the tools you have.
i will test cleaning the lenses with alcohol wipes and see if that fixes the issue, I have done this alot before perhaps im not doing it enough.
in recap i will try to do the filtering. I wasnt doing that because we needed the full cloud density but i will test that out.
- Full Name: Marty
- Company Details: Survey Company
- Company Position Title: Scanner Tech
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
Happens with all gear. You need to filter out with the routines in your software. In scene these are stray points etc,... in Riscan it's isolated points with a minimum number in a certain radius.CountryBoy wrote: ↑Thu Oct 21, 2021 3:36 pm We get that a lot if it is too humid or if it has just rained.
