Hi guys
Haven't post for while, thought I'd share a tip for Faro Scene that I discovered.
Scene used to drive me crazy with the amount of times it crashed. Now it hardly ever crashes, in fact I can't remember the last time it did.
All I do is regularly "unload all scans and pictures". This chucks a large amount of data out of RAM. The scans normally get loaded into RAM when you Quick view a scan.
I used to get lots of crashes when I saved after deleting points. If I unload all scans it never crashes.
I got in the habit of doing this regularly and now I have no problems.
Regards, Andrew
Reducing Scene crashes to almost zero
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 183 times
- Been thanked: 548 times
Re: Reducing Scene crashes to almost zero
That is indeed true. Always unload all scans when doing steps in Scen. Also when preprocessing create a "scan point cloud" while you're at it.
- pmuren
- Full Name: Paul Muren
- Company Details: Coast 2 Coast Surveys
- Company Position Title: 3D Technical Development Lead
- Has thanked: 6 times
- Been thanked: 3 times
To add to this, one thing that has occasionally caused Scene to crash for me is deleting a cluster while its correspondence view is still open.
I frequently re-organize clusters to achieve better cloud-to-cloud results, and I use the correspondence view to decide which scans to move into new clusters.
So, another way to prevent crashes is to always close the views of a cluster before you delete it.
- Leandre Robitaille
- Company Details: Cima+
- Has thanked: 61 times
- Been thanked: 246 times
Don't trust this. Trust me it doesnt work, scene will crash even with all scans unloaded and view closed when deleting clusters
Best and safest way to delete a cluster is to save before. I usually keep a "delete cluster"where I drop all the clusters I want to delete into and delete it after a save.
- pmuren
For what it's worth, this does work for me. Perhaps the difference is in our Scene versions or specific hardware.
- Full Name: Owen Dew
- Company Details: Micheal J Lonsdale
- Company Position Title: Trainee survey technician
- Country: Uk
Where do you go to 'all scans and pictures all I can seem to find is how to unload each scan individually?fobos8 wrote: ↑Thu Sep 30, 2021 11:10 am Hi guys
Regards, Andrew
- Full Name: Raimund Klink
- Has thanked: 193 times
- Been thanked: 25 times
Right click the cluster
\o/
