I’ve been in touch with Navvis and ClearEdge. I recall this issue now, as we have used ClearEdge in the past. It wants to fit the pipes to the cloud from the P.O.V. of the scanner. Hence each scan needs to be from one “spot”.
ClearEdge has an automated feature (which requires a stationary scan) and an semi-automated feature. The semi-automated extraction can still fit piping to the cloud, you have to give the software more direction, i.e. click on the point cloud and tell it to find a pipe from the selected data.
This was a big bummer for me as we're getting close to purchasing the VLX. I'm having some second thoughts considering this drawback.
Does anyone have experience here?
VLX and ClearEdge 3d not compatible
- I have made 50-60 posts
- Full Name: Andrea Gavagnin
- Company Details: Geolab.info Gavagnin.com
- Company Position Title: Libero Professionista
- Country: Italy
- Skype Name: andrealowa
- Has thanked: 23 times
- Been thanked: 9 times
Re: VLX and ClearEdge 3d not compatible
good morning, I think it is not a problem of the VLX as you describe it, but of all mobile systems, be it BLK2GO, KAARTA, Pegasus, Photogrammetry .... if clearedge needs a cloud structured by terrestrial static scanner, hardly could you get something out of a dynamic scan ...
- berdindc
- Full Name: Dan
- Company Details: Berding
Correct, all mobile scanners would encounter the same issue. Still an issue...
- Full Name: Kelly Cone
- Company Details: ClearEdge3D Inc
- Company Position Title: V P of Product Management
- Skype Name: Gkellycone
- Been thanked: 6 times
So... we are a few months away from beta testing a version that DOES support mobile data for unstructured piping. #Surprise! (You didn't hear it from me!) Seriously though, we're not quite ready to ship anything yet, but a beta should be available within a few months. If you're interested... let us know!
I should note, this will mean that all of the main EdgeWise workflows will then support unstructured data!
- Structure
- Duct
- Cable Trays
- Walls (as of late 2020)
- Pipes (Releasing in early 2022!)
- Structure
- Duct
- Cable Trays
- berdindc
- Full Name: Dan
That's great news Kelly....I figured you guys would be on it, given the trajectory of the equipment changes and potential uses...!
Most of our scan data is fed to our client(s)....be great to connect up them with you for beta testing when the time is right. We are beginning a 1,700,000 square foot job soon that is slammed with piping. Will be gathering with FARO (will mostly be running control scans, but will need to grid off for use in ClearEdge3d) and then we will walk the area with the VLX.
- Full Name: Frieder Kirn
- Company Details: Bentley Systems
- Company Position Title: Product Manager
- Has thanked: 31 times
@kelly Great to hear that you are working on that. If NavVis can support you please let us know
Would love to see some automatic pipe modelling based on NavVis data.
The automated modelling of walls and levels + semi automated modelling of pipes works btw:
