PDAL export setup coordinates
Please post all open source software related items here, eg OpenScanTools
MarkJLane
6
Full Name: Mark Lane
Company Details: Faro Technologies
Company Position Title: ANZ Account Manager
Has thanked: 25 times
Been thanked: 43 times
Post by MarkJLane »
I use PDAL heavily in my post-processing pipeline, but I'd like to extract the coordinates of each scan to a TXT file also.
Is this possible with PDAL or should I delve into libE57?
Mark Lane
Sydney, Australia
TLS Tools
GeoSLAM
smacl
13
Full Name: Shane MacLaughlin
Has thanked: 627 times
Been thanked: 657 times
Re: PDAL export setup coordinates
Post by smacl »
Mrk wrote: Thu Aug 19, 2021 4:27 am I use PDAL heavily in my post-processing pipeline, but I'd like to extract the coordinates of each scan to a TXT file also.
I haven't used PDAL so can't comment on that, but have worked on extracting setup info from libE57. This demands some proficiency in C++ and a little bit of slightly unusual math as orientations are stored in quaternions rather than the more normal transformation matrix or set of angles. All very doable but not exactly trivial either.
Shane MacLaughlin
Atlas Computers Ltd
www.atlascomputers.ie
SCC Point Cloud module
jedfrechette
14
Full Name: Jed Frechette
Company Details: Lidar Guys
Has thanked: 62 times
Been thanked: 220 times
Post by jedfrechette »
I don't think there is an easy way to get that info directly with PDAL, but with a little programming (not necessarily C++) it is pretty easy to extract yourself even without using libe57 or any other libraries.
In e57 files all the metadata, including scan positions, is essentially just an xml file appended to the end of the data file. It's plain text so you don't even need any special tools to inspect it.
We've done the same thing you're looking for with a small amount of Python code. In our case, that code runs within the Python interpreter of a larger application so it was easier to implement a metadata reader from scratch than to add an external library dependency. Our code is mostly standard library Python, maybe with some Scipy thrown in to handle transforms. I'm happy to share snippets to get you started if you want to go that route.
smacl
13
Post by smacl »
jedfrechette wrote: Thu Aug 19, 2021 3:30 pm I don't think there is an easy way to get that info directly with PDAL, but with a little programming (not necessarily C++) it is pretty easy to extract yourself even without using libe57 or any other libraries.
Sounds like a good route if you're just concerned with the metadata. If you need to apply the setup information to get a unified set of points, where each point can be linked back to a setup (e.g. to translate an E57 file to a PTX file), libe57 and some C++ may be a little bit difficult to avoid.
Shane MacLaughlin
Atlas Computers Ltd
badam
2
Full Name: Adam Berta
Country: Hungary
Has thanked: 52 times
Been thanked: 297 times
Post by badam »
smacl wrote: Fri Aug 20, 2021 10:23 am
I've used libe57 with minimal knowledge of c++. I've created a command line app which extracts the 2D images (6 cubeface) from cyclone register/register360 exported structured e57s and their position, quaternion and then i used them in potree. There are small application examples on the libe57 webpage. The worst thing for a beginner like me is the casting of the variables. And the pointers. Especially if you come from a script languages like python, shell, etc.
