Potree is an application that offers so much promise, and yet it eludes me.
My goal is to install it in a webserver, reachable by anybody, more specifically here:
http://jfknumbers-forum.org/potree-1234
It is known that there are at least two installations that have been properly deployed and are therefore Internet reachable:
(1) This one, of course:
https://github.com/potree/potree
[scroll to the bottom of the page, there are many examples]
(2) Another one, at the University of Arkansas.
http://view3d.cast.uark.edu/petroglyphpoint/index.html
The 2nd. ones is running Windows IIS and therefore the owner can only provide limited help for the Linux issues.
The OS of the first one is unknown, but it seems that Potree was developed on Windows and therefore it works fine on Windows.
TIA,
-Ramon F. Herrera
JFK Numbers
NB: It is well known that Potree works perfectly listening to 'localhost' ports. That is not Internet reachable.
Has anybody been able to deploy Potree on a Linux server?
- I have made 70-80 posts
- Full Name: Ramon F Herrera
- Company Details: Free Open Source3D Model of Dealey Plaza
- Company Position Title: Founder - Chief Bottle Washer
- Country: US
- Has thanked: 8 times
- Country: US
Re: Has anybody been able to deploy Potree on a Linux server?
These is my Apache configuration:
It is presumably correct, since this identically configured service is working fine:
http://jfknumbers-forum.org/hello-world
This is the output that I get when attempting to reach Potree:
Thanks!
-Ramon F. Herrera
JFK Numbers
Thanks!
-Ramon F. Herrera
JFK Numbers
- Full Name: Markus Schuetz
- Company Details: potree.org
- Company Position Title: developer
- Country: Austria
- Been thanked: 5 times
If it works localy, all you need to do is upload the folders "build", "examples", "libs" and "pointclouds" to your web server. You do not need to - or rather should not - install node on your server and usually you should not need to configure anything since the default configuration is fine. It should work with default configurations of apache and nginx. If you're using IIS, you may have to add *.hrc and/or *.bin to your list of mime types in your IIS configuration.
- Full Name: Jed Frechette
- Company Details: Lidar Guys
- Has thanked: 62 times
- Been thanked: 220 times
It's been a while since I've done it, but I remember deployment to a typical shared Linux web host being pretty straight forward. From memory, the method I used was to use potreeconvertor to generate the support files. Edit the HTML file to set various viewer parameters, following the examples on GitHub. Then upload the whole lot to the webserver. Basically this:
http://www.potree.org/getting_started.html
It looks like you might need to update your config to point to the actual HTML file defining your viewer.
- Country: US
I am at that point right now, Jed.jedfrechette wrote: ↑Sat Aug 29, 2020 5:23 pm
Getting a properly functioning cmake is my current challenge. Both source and binary distributions have problems.
Thanks!
-Ramon
JFK Numbers
- Country: US
I am glad to report that I have that great application finally domesticated:mschuetz wrote: ↑Sat Aug 29, 2020 2:21 pm Hi,
http://jfknumbers-forum.org/potree/examples/
My next step is, of course to convert my 2 Dealey Plaza point clouds.
http://www.dealey-plaza.org/this-govern ... s-Schuetz/
I noticed several features that may be useful for my one-location project. This, for instance, can display the elevation of the presidential vehicle as it went downhill to meet its doom and become part of (unresolved) history:
http://jfknumbers-forum.org/potree/exam ... ofile.html
One feature that I would like to implement (request?) is the ability to [Shift] click on the dot icon, when multiple points are needed, to mark the trajectory of a 1961 Lincoln Continental limousine, for example.
American Model (Official by Ford):
https://www.turbosquid.com/3d-models/co ... el-1350776
Russian Model:
https://hum3d.com/3d-models/lincoln-con ... -100-1961/
Thanks!
-Ramon
JFK Numbers
