By the way.. this is not a feature. Its a F*** you 5 projects deep that all need to be re-exported. It's a glitch. fix it.pburrows145 wrote: ↑Fri Jan 24, 2020 12:52 pm What you are seeing is the mixed-pixel filter in action which gets rid of erroneous points (at the point of data import). When viewed from the scan-position, this looks like "cel-shaded" cartoon graphics.
You can reduce the aggressiveness of the filter in Cyclone/REG360 as you choose.
Black lines in RealView when importing into Recap - RTC360
- Carbix
- Full Name: Daniel Loney
- Has thanked: 33 times
- Been thanked: 50 times
Re: Black lines in RealView when importing into Recap - RTC360
- pburrows145
- Full Name: Paul Burrows
- Has thanked: 109 times
- Been thanked: 123 times
I will address this with Guy Cutting the PM for REGISTER.
I will try and word it a little nicer.
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 52 times
- Been thanked: 297 times
Well i think not the mixed pixel is the worst issue, that is helpful in lot of the cases. Rather then how recaps handles/not handles the images. If i recall correctly you can disable completelly the mixed pixel. I'm not sure currently.pburrows145 wrote: ↑Thu Mar 10, 2022 10:23 am I will address this with Guy Cutting the PM for REGISTER.
But the main issue is that there is no standardized way of writing e57 everyone uses their solution especially when it comes to the image part. As a matter of fact i like the cubemaps.
- pburrows145
Yes, there are several different ways of handling E57 export/import... it's a bit fragmented right now.badam wrote: ↑Thu Mar 10, 2022 11:10 amWell i think not the mixed pixel is the worst issue, that is helpful in lot of the cases. Rather then how recaps handles/not handles the images. If i recall correctly you can disable completelly the mixed pixel. I'm not sure currently.pburrows145 wrote: ↑Thu Mar 10, 2022 10:23 am I will address this with Guy Cutting the PM for REGISTER.
- Full Name: Noel Angelo Enriquez
- Company Details: McNeil Engineering
- Company Position Title: HDS-Technician
So im actually just running into this problem and found this postpburrows145 wrote: ↑Fri Jan 24, 2020 12:52 pm What you are seeing is the mixed-pixel filter in action which gets rid of erroneous points (at the point of data import). When viewed from the scan-position, this looks like "cel-shaded" cartoon graphics.
In cyclone, i usually just export PTGs,
how would i adjust the aggressiveness of the filter in cyclone before exporting?
additionally, what am i aiming for when i filter, to avoid this issue with the black lines?
- pburrows145
You need to change the filter "pre" import - you can find it within the settings tab under "filtering"Noscans wrote: ↑Wed Dec 20, 2023 6:37 pmSo im actually just running into this problem and found this postpburrows145 wrote: ↑Fri Jan 24, 2020 12:52 pm What you are seeing is the mixed-pixel filter in action which gets rid of erroneous points (at the point of data import). When viewed from the scan-position, this looks like "cel-shaded" cartoon graphics.
