How to Remove Realview Data
Discuss Autodesk ReCap Studio software here.
TigerAC3
5
Full Name: Adam
Company Details: Manufacturing
Post by TigerAC3 »
I have a Recap project that has ~500 scans. I have deleted all the points outside of an area and saved as, while selecting the delete points option. My issue is all the realview data remains for every scan location. Due to this the project is still over 100GB in size. I am trying to reduce the project size as much as possible so that it is easier to share. Is there an easy way to delete all the realview data for locations that are outside of the remaining area? I have attached a screenshot to better illustrate.
DanielNMP87
7
Full Name: Daniel Neagu
Company Details: XYZ
Re: How to Remove Realview Data
Post by DanielNMP87 »
how about you make a copy of rcp open it in registration mode remove the scans that you don't need and then save...
Hope it helps!
topogeo
9
Full Name: piercarlo roasio
Country: italy
Has thanked: 24 times
Been thanked: 25 times
Post by topogeo »
Often problem ..
I solved by deleting the scans one by one, by clicking on the "x" of the scans list that you see on the right in the image of the scans.
But .. I do not know how to select a block ... I unfortunately, I select them one by one (and each singols snatch me apsettare many tens of seconds to be deleted).
Piercarlo
GBP88
3
Full Name: Gonzalo Pampuro
Company Details: Techint
Country: Argentina
Post by GBP88 »
Hi.
Same issue over here. Is there a better way to delete multiple scans?
And what about removing realview data from the project entirely? I only need the point cloud and not the realview data.
JFLAMM
2
Full Name: Jason
Company Details: Sterling Company
Company Position Title: Professional Land Surveyor
Post by JFLAMM »
If you export a unified .rcp from the project, it'll be just the cloud data. Prior to that, you can go to the box on the right and turn off individual scans. You can delete and clip what's visible to your liking, then hit the top button on the left, slide over to the export button and hit it. It will just export the cloud in its current state. This does make it one cloud. You lose the individual scan functionality.
pipingdesigner
3
Full Name: Paul Bowers
Company Details: Society of Piping Engineers and Designer
Has thanked: 39 times
Been thanked: 11 times
Post by pipingdesigner »
Can't you just delete all the RCC files?
https://www.laserscanningforum.com/foru ... 193#p78193
VXGrid
7
Full Name: Martin Graner
Has thanked: 160 times
Been thanked: 175 times
Post by VXGrid »
GBP88 wrote: Wed Nov 24, 2021 2:57 pm Hi.
What Jason said for deleten them all.
But for selecting certain scans:
Isn't it possible to move selected scans to a cluster and delete the cluster?
I mean if you select scans and drag them (in the list view)
