large pointcloud
sss
Full Name: Craig Greaves
Company Details: Site Surveying Services
large pointcloud
Post by sss » Fri May 19, 2017 3:55 pm
i have a job in cyclone with around 8 scans on a high quality, resulting in lots of overlapping data, is there a way to filter this data at say 1mm to reduce the size of the export file?
i tried unifiying the model but when i try to export an .E57 it says no pointcloud data?
thanks in advance
pburrows145
Full Name: Paul Burrows
Skype Name: pburrows145
Re: large pointcloud
Post by pburrows145 » Fri May 19, 2017 4:15 pm
You can unify (try 3-6mm) and export in PTS instead if needed: where is the data going?
I'd say 8 scans on high-resolution is quite a small job to be fair.
SCCS HDS
Full Name: Phil Marsh
Company Details: SCCS
Skype Name: Phil.H.Marsh
Post by SCCS HDS » Fri May 19, 2017 5:46 pm
You can reduce each ScanWorld's point cloud without unifying the data. This will then allow you to export the structured data as an e57. :ugeek:
Let me if you would like a remote login sesssion to show you how? ;)
SCCS - The Survey Equipment Company l Sales, Hire & Support l Leica HDS Laser Scanning
T: 01480 404888 l M: 07540 201383 l E: phil.marsh@sccssurvey.co.uk
W: www.sccsurvey.co.uk/hds l N: SCCS News l T: @SCCSHDS
xyzsystems
Full Name: XYZ Systems
Company Details: XYZ Systems
Post by xyzsystems » Fri May 19, 2017 7:22 pm
with 8 scans, you're better off just individually reducing each one and then exporting from the registered modelspace
pburrows145
Post by pburrows145 » Mon May 22, 2017 10:13 am
thanks in advance
Where is the data going, such that you need an E57 file, specifically?
