Conversion of imp (cyclone) to lfd(AVEVA E3D)
Mutiu
Full Name: ALIMI MUTIU OPEYEMI
Company Details: ARIOSH LIMITED
Company Position Title: TRAINEE FIELD SERVICES ENGINEER
Country: NIGERIA
Post by Mutiu »
Good day all,
I am trying to convert a data from .imp (cyclone) to .lfd (LFM) so i can use it in E3D (1.1 and 2.1)
I export the data in e57 format and import into LFM 4.2.1.1 x64 Advanced Mode, but the software crashes afterwards. Similar problem occurs for .ptx.
Note that the lowest data size i have so far after export in e57 is 13.7GB.
What might be the reason for crashing and is it possible that a higher LFM version would solve the problem?
Thanks for your attention.
anonimou
Full Name: Delio Pontes
Re: Conversion of imp (cyclone) to lfd(AVEVA E3D)
Post by anonimou »
I think I had problems before to import e57 or ptx working with the version LFM 4.2
I think was solved with version 4.3
But if you can, try with a recent version, I never had conversion problems with 4.4.
Return to “AVEVA Suite”
