Import E57 in 3DR script does not show in Tree-View
Discuss Leica Cyclone 3DR software here.
amir_mizrachi
Full Name: Amir Mizrachi
Company Details: onsight
Company Position Title: CTO
Country: Israel
Post by amir_mizrachi »
I am a newbie to Cyclone 3DR javascript.
Why do the following code - which should only suppose to import an E57 file - ended successfully but I cannot see the point cloud data in 3dr tree view?
Code: Select all
/// <reference path="C:\Program Files\Leica Geosystems\Cyclone 3DR\Script\JsDoc\Reshaper.d.ts" />
var res = SSurveyingFormat.ImportCloud("C:/Test.e57", 0, true);
if (res.ErrorCode == 0)
    print("\nThe import of the object succeeded.");
else
    throw new Error("The import of the object failed.");
Thanks!
gilles_3DR
Full Name: Gilles Monnier
Company Details: Hexagon
Company Position Title: 3DR Technical Manager
Been thanked: 28 times
Re: Import E57 in 3DR script does not show in Tree-View
Post by gilles_3DR »
by default, none of the results (from import or data processing or...) are added into the 3dr tree view.
You need to define what needs to be added or not.
For this SSurveying.ImportCloud() function, you need to loop over the elements in res.CloudTbl and add them into the document: AddToDoc() function
Return to “Leica Cyclone 3DR”
