Surphaser 25HSX Short Range / High Precision scanner available for hire
Discuss Surphaser hardware here.
mls
14
Full Name: Paul Casson
Company Details: multipass 3d laser scans ltd
Post by mls »
Hi all.
If anyone is interested in hiring a Surphaser 25HSX Short Range high precision scanner in the UK please drop me a message.
This version of the Surphaser is a crossover between large volume scanners and metrology grade/handheld scanners. Minimum range 0.5 metres. Maximum range is up to 7 metres with sub millimeter accuracy and super fine resolution. The laser diameter is focused to 0.5mm diameter at 3m range, so it will record fine detail with reduced edge blurring and very clean pointcloud output. The specs are in the attached PDF. This unit has built in inclinometers for both upright and inverted deployment. Great for modeling fine surface detail or scanning mechanical items, pipework etc.
Paul
Multipass 3d.
07810 130952
Return to “Surphaser”
