No idea where to start with what I want to achieve
Introduce yourself.
Mike Annear
12
Full Name: Mike Annear
Company Details: The Yard Brisbane
Company Position Title: Manager - 3D Design and Scanning
Has thanked: 96 times
Been thanked: 159 times
Re: No idea where to start with what I want to achieve
Post by Mike Annear »
Hi Jay,
Wow, I used to be an exhibition designer in the 90's, that is how I learnt to use 3D AutoCad/Max.
The cheapest, simplest, easiest solution would be a Faro S70 or BLK360 scanner combined with Rhino 3D.
You can export FBX out of Rhino to import into Max
You might find a lot of your clients are using Sketchup Pro, that will accept Rhino files as a 3D DWG
Cheers,
Mike.
Mike Annear
www.mikeannear.com
QLD, Australia.
Return to “Introductions”
