Click Here to View or Bid on This Auction ItemUp for bid is a Leica ScanStation 3000 HDS 3600 3D Laser Scanner System. This unit is in great physical shape, looking to be in like-new condition. It was pulled from a working environment and is tested working.
- INCLUDED IN THIS AUCTION IS: RIGHTS TO THE ORIGINAL SOFTWARE LICENCE* for Leica Geosystems HDS Cyclone Scan Software that was purchased for over $50,000. (THIS LICENSE MAY OR MAY NOT BE TRANSFERABLE)*
* This software licence MAY BE transferable IF YOU PURCHASE THE SOFTWARE MAINTENANCE PROGRAM - to the winner of the auction, we will put you in touch with your local Leica HDS Software Regional Sales Manager who would make that determination with the buyer.
** The ScanStation HDS 3000/3600 model has reached end of life, and should it ever break, new parts are no longer available.
Features:
· Maximum 360° x 270° field-of-view
· Unique dual-window design
· Fully selectable field-of-view and scan density
· Bore-sighted digital camera for automatically calibrated photo overlays
· <6 mm spot size @ 50 m
· 6 mm positional accuracy @ 50 m
· Height-of-instrument (H.I.) measurement
· Setup over survey point
· Flexible "hot-swap" power supply system
· QuickScan™ button
Description:
With the Leica HDS3000, high-definition surveying has never been easier and friendlier for surveyors and measurement professionals. For example, it supports standard surveying procedures, such as instrument setup over a known or assumed survey point, height-of-instrument measurement, and instrument orientation. These same features are also valuable for automated geo-referencing of captured data to local coordinate systems. The new QuickScan mode allows users to quickly and easily define the extents of the scanning scene by simply pushing a button on the scanner. Efficient battery swapping and improved weight/portability allows for even more flexible and friendlier field operations.
Just as significant as its ease-of-use, the HDS3000 takes the industry-leading accuracy (6mm at 50m) and versatility of its popular predecessor, the Cyrax® 2500, to the next level of productivity. It combines SmartScan Technology™ with a maximum 360° horizontal field-of-view and an equally impressive maximum 270° vertical FOV. In a nutshell, the Leica HDS3000 is a versatile, multi-purpose scanner that combines high efficiency with high accuracy for a broad range of civil engineering, plant and building projects.
Items Included:
•(1) Leica ScanStation 3000 HDS 3600 (Serial# 410690702)
•(1) Leica ScanStation Power Supply
•(1) Twin Target Pole with 3"X3" Targets
•(2) 6" Planar Turn and Tilt Target Disc
•(1) Rolling, Locking Plastic ScanStation Case
•(2) Leica Battery - Includes (2) Power Supply
•(2) Battery Carrying Case
•(1) Leica GDF22-1 Tribrach with Optical Plummet
•(1) Tribrach Base for 6" Targets
•(2) Magnetic Base for 6" Targets
•(1) 25+ Foot Cat-5 Network Cable
•(1) Leica ScanStation HDS3000 User Manual
•(1) Pack of Misc. Cleaning Supplies for ScanStation
•(BONUS) RIGHTS to the Leica HDS Cyclone Software License (May not be transferable)
Please contact us for any questions!
Thanks for Looking!
Leica ScanStation - 3000 HDS 3600, 3D Laser Scanner System!
- Phil Marsh
- Administrator
- Full Name: Phil Marsh
- Skype Name: phil.h.marsh
- Has thanked: 117 times
- Been thanked: 36 times
- 2
- Full Name: TARIQ MOHAMAD HASAN
- Company Details: Diwan
- Company Position Title: CEO
- Country: Egypt
