How to Remove Realview Data
Discuss all Autodesk ReCap Studio related issues here.
TigerAC3
3
Full Name: Adam
Company Details: Manufacturing
Post by TigerAC3 »
I have a Recap project that has ~500 scans. I have deleted all the points outside of an area and saved as, while selecting the delete points option. My issue is all the realview data remains for every scan location. Due to this the project is still over 100GB in size. I am trying to reduce the project size as much as possible so that it is easier to share. Is there an easy way to delete all the realview data for locations that are outside of the remaining area? I have attached a screenshot to better illustrate.
DanielNMP87
Full Name: Daniel Neagu
Company Details: XYZ
Re: How to Remove Realview Data
Post by DanielNMP87 »
how about you make a copy of rcp open it in registration mode remove the scans that you don't need and then save...
Hope it helps!
topogeo
Full Name: piercarlo roasio
Country: italy
Has thanked: 13 times
Been thanked: 16 times
Post by topogeo »
Often problem ..
I solved by deleting the scans one by one, by clicking on the "x" of the scans list that you see on the right in the image of the scans.
But .. I do not know how to select a block ... I unfortunately, I select them one by one (and each singols snatch me apsettare many tens of seconds to be deleted).
Piercarlo
GBP88
Full Name: Gonzalo Pampuro
Company Details: Techint
Country: Argentina
Post by GBP88 »
Hi.
Same issue over here. Is there a better way to delete multiple scans?
And what about removing realview data from the project entirely? I only need the point cloud and not the realview data.
