Mirrroring surface
Discuss all BLK2GO | BLK2GO Pulse | BLK2FLY related products here.
NimaKarkhaneh
Full Name: Nima Karkhaneh
Company Details: Bennett + Bennett
Company Position Title: Senior Spatial Surveyor
Re: Mirrroring surface
Post by NimaKarkhaneh »
I agree, I bleave cutting point cloud by aqustion time does not work for mirrors, however it would be great to have this option, I already have some scans with BLK2GO which part of data is not good and I want to cut that based on time and it seems impossible by current software.
SlavikusAstana
3
Full Name: Vyacheslav Yurchenko
Company Details: ST-Vision
Country: Russia
Skype Name: Slavikus_Astana
Has thanked: 10 times
Been thanked: 14 times
Post by SlavikusAstana »
youtu.be/J3j7FsHKQ0o
my "favorite" mirrors.
Scanned a room with a carbon dioxide tank. The surface is a perfect mirror.
Laser scanning, panoramic shooting
piero
9
Full Name: Pier Carlo Ricci
Company Details: Artificio Digitale Snc
Company Position Title: Artificio Digitale Snc
Country: Italia
Skype Name: Pier Carlo Ricci
Post by piero »
:( So the trouble is real … I think it’s still a great limit of this mobile scanner … surely in our usual jobs
13
Has thanked: 627 times
Been thanked: 657 times
SlavikusAstana wrote: Mon Oct 18, 2021 5:11 pm
Tough one to crack for sure. It would be interesting to see if a photogrammetric solutions would give better results, I suspect they would but still would suffer from other problems. Thomas Whelan's paper on the subject of detecting mirrors in scanned data makes for an interesting read (if a bit technical). It involves using specific targets with a recognisable pattern that can be identified in the scan data and used to isolate the mirror. Results suggest it works well for planar mirrors (i.e. not curved) and static scanning. I doubt it would cope with your carbon dioxide tank above, nor does it work with SLAM. I'd love to get a copy of the above data, though more out of interest than being likely able to do much with it.
Shane MacLaughlin
Atlas Computers Ltd
www.atlascomputers.ie
SCC Point Cloud module
13
piero wrote: Tue Oct 19, 2021 7:41 am :( So the trouble is real … I think it’s still a great limit of this mobile scanner … surely in our usual jobs
I think for a mobile scanner, the main issue is being able get the timed trajectory file to go with the scan data and the times on each point such that the two can be connected. Once you have this, you can apply similar solutions to those afforded by static scanning, albeit working with cylindrical polar coordinates rather than spherical polars.
Shane MacLaughlin
Atlas Computers Ltd
mikajahkola
I have made 90-100 posts
6
Full Name: Mika Jahkola
Company Details: Myymore Oy
Country: Finland
Has thanked: 19 times
Been thanked: 23 times
Post by mikajahkola »
The shiny tank inside a room is an extreme case. In the more typical case you have one or several planar mirrors on the walls of a room projecting false images into the neighboring rooms.
There splitting the point cloud into parts by acquisition time could work quite nicely. In principle you would split the point cloud each time you enter a new room. Then you could delete mirrored points spilling into the neighboring rooms manually just like you would do with static scans.
13
Just adding a quick link to another thread also covering this topic for reference purposes; https://laserscanningforum.com/forum/vi ... 804#p95804
Shane MacLaughlin
Atlas Computers Ltd
13
mikajahkola wrote: Tue Oct 19, 2021 9:41 am The shiny tank inside a room is an extreme case. In the more typical case you have one or several planar mirrors on the walls of a room projecting false images into the neighboring rooms.
Great idea! It doesn't distinguish between windows and mirrors and assumes the non-reflective side of the mirror is closer a wall than the reflective side, though is still worth trying as an algorithm for a semi-automated solution that could work well in most cases.
Shane MacLaughlin
Atlas Computers Ltd
SlavikusAstana
3
Country: Russia
smacl wrote: Tue Oct 19, 2021 8:35 am I doubt it would cope with your carbon dioxide tank above, nor does it work with SLAM. I'd love to get a copy of the above data, though more out of interest than being likely able to do much with it.
https://storage.st-vision.kz/forum/CO2.lgs
https://storage.st-vision.kz/forum/CO2.e57
or
https://drive.google.com/drive/folders/ ... sp=sharing
I exported this piece especially for you.
PS: scan performed on RTC360
Last edited by SlavikusAstana on Tue Oct 19, 2021 4:19 pm, edited 1 time in total.
13
SlavikusAstana wrote: Tue Oct 19, 2021 2:29 pm
Many thanks :D
Shane MacLaughlin
Atlas Computers Ltd
Return to “Leica BLK2GO | BLK2GO PULSE | BLK2FLY”
