GTL-1000 Scanner | TAS Concrete Testimonial
Topcon GTL-1000, Trimble SX10 & VX, Leica MS60, MS50
14
Has thanked: 224 times
Been thanked: 124 times
Post by Jason Warren »
youtu.be/RdESzfVKyG4
Image Topcon Positioning Systems
The GTL-1000 combines a fast laser scanner with a robotic total station, allowing you to perform layout and scanning for daily construction verification on a single setup. Use our plug-in for Revit® and AutoCAD® to automate point creation and easily import and export layout files to and from the field. This complete office-to-field workflow reduces costly rework while increasing efficiency, accuracy and productivity.
Watch TAS Concrete use the GTL-1000 to check floor flatness and floor levelness (FF/FL) specifications just after the pour at The Allen Tower Project in Houston, Texas.
Topcon is helping contractors like TAS simplify construction verification workflows such as quality control, checking progress, documenting as-builts and ensuring projects are built 100% to plan.
Interesting video... ;)
Co_Founder
LaserScanningForum
10
Has thanked: 316 times
Been thanked: 299 times
Re: GTL-1000 Scanner | TAS Concrete Testimonial
The GTL-1000 is a great piece of kit and well priced from memory, hybrids like this and scanning total stations such as the newer MS60, SX10,SX11,SX12 series and this are the ideal tool for this type of application. The GTL-1000 is still the fastest in this line up for this kind of work where you need to combine total station control with scan data in an efficient workflow.
Return to “Total Station Scanners”
