Tank volume analysis
Discuss all FARO BuildIT CONSTRUCTION related software issues here.
JoshuaBigham
4
Full Name: joshua bigham
Company Details: FARO
Company Position Title: PO - BuildIT Construction
Re: Tank volume analysis
Post by JoshuaBigham »
Raimund58 wrote: Tue Aug 27, 2019 2:58 pm
scott.diaz wrote: Tue Aug 27, 2019 2:42 pm The AsBuilt/PointSense tools only work with vertical vessels.
This looks like a flaw to me. Why does this only works with vertical vessels?
BuildIT handles any orientation, I've even calculated the volume of a square/rectangular tank.
VXGrid
4
Full Name: Martin Graner
Has thanked: 80 times
Been thanked: 78 times
Post by VXGrid »
scott.diaz wrote: Tue Aug 27, 2019 2:42 pm The example from the website looks like a horizontal vessel. The AsBuilt/PointSense tools only work with vertical vessels. PM me or send me an email and i will have one of our engineers get you a vertical tank for testing in As-Built. You could use the same for BuildIT.
Can't you just rotate the point cloud so the object is aligned in a way the software can use it?
scott.diaz
12
Full Name: Scott Diaz
Company Details: FARO Technologies
Company Position Title: Business Development
Post by scott.diaz »
Yes of course and this is fine for shell deformation analysis in As-Built. Actually you dont need to do that just for shell analysis. But if you want to use the function for volume analysis (how much liquid is in the tank at various interval heights) then this is not useful. Like Josh said though, BuildIT doesnt care about orientation like As-Built. It is a much stronger analysis tool
Baasan
Full Name: Baasan
Company Details: Ochir
Country: Mongolia
Skype Name: live:bbumbuul
Post by Baasan »
Hello, how does it work with Tank volume analysis for tilted to one side horizontal tank?? the tank's right side is shifted by 15cm to earth due to earth shift. the volume analysis shows a tank volume that would be normal (not tilted to side due to earth shift) horizontal tank but mine is not.
Baasan
Full Name: Baasan
Country: Mongolia
Post by Baasan »
Looking for info on how to do Tank volume analysis on Vertical Tank. The demo on faro site is only for vertical tank. Thank you
mr. Scott Diaz, i saw post that you have demo file for vertical tank, could you contact me as i would like to get it. As im a new member to this site there is restrictions on to send pm.
Thanks.
Jamesrye
13
Full Name: James Rye
Been thanked: 24 times
Post by Jamesrye »
The production of accurate strapping tables from laser scan data is a service that we provide to a number of users on this forum. Our in house software takes into account deadwood and produces a strapping table with a volume for every millimeter. Tilted tanks are no problem. If you are interested in a quote for the processing, please send me a PM.
http://www.storagetanksurveys.com/
Return to “FARO BuildIT CONSTRUCTION”
