Faro X330 " No data received from scanner. Scannig will not be possible.Please restart the scanner.
- ysntsn
- 3
- Full Name: Yasin TOSUN
- Company Details: HYSurvey
- Company Position Title: Engineering
- Country: TURKEY
Hi Everyone,
We have a problem with Faro Focus X330,
really interesting problem,I think the problem is in the software.
scanner as if opening in safe mode. While opening, it waits for a long time in the "waiting for data" section and an error message appears.
We tried boot up and reset but not changed.
Manage menü doesnt open. Doesnt see sd kart.
But when i hold down the start stop button on the scanner it scans and saves to the sd card. Doesnt show on the screen.
Does anyone have a suggestion wonder?
Thank you,
Thank you,
- LPaulCook
- Full Name: L Paul Cook
- Company Details: Land surveyor doing LiDAR
- Has thanked: 47 times
- Been thanked: 44 times
Re: Faro X330 " No data received from scanner. Scannig will not be possible.Please restart the scanner.
I would do what you have done and since that didn't work I would reinstall the firmware.
FARO has an knowledge base on how to do that and you can download the firmware from them to if you don't have the last version they made.
If that fails it sounds like you will need to send it in for servicing.
I have a X330 and S350 so I do have lots of experience with the X330 but never had the issue have....
Good luck!!!
Paul
Good luck!!!
Paul
L. Paul Cook, PLS
www.LPC3D.com
www.LPC3D.com
- ysntsn
- 3
- Country: TURKEY
Thank you for answer,
But Manage menü doesnt open :/
Do we have any other chance to update the software?
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
From the picture the scanner is not detecting the SD card. Did you try changing SD card?
- LPaulCook
I have never seen that happen.
Maybe you need to reinstall the operating system then install the firmware but I have no idea how to do that.... maybe a computer repair shop can help you. What the heck.. the next option is to ship it in for repairs anyway....
Good luck to you!!
Good luck to you!!
L. Paul Cook, PLS
www.LPC3D.com
www.LPC3D.com
- LPaulCook
Or maybe you accidentally locked the SD card.... I did that once...
L. Paul Cook, PLS
www.LPC3D.com
www.LPC3D.com
- jcoco3
- Full Name: Jonathan Coco
- Company Details: Consultant
- Has thanked: 70 times
- Been thanked: 157 times
Superglue is a must Have learned this the hard way involving a second flight across the country and a re-scan of the project only to have one of my people get stuck in an airport due to winter storms. Think he still has the tiny blanket the airline gave him.
I wish a reputable SD card manufacturer would just make some without the lock switch.
- TommyMaddox
- Company Details: ONSITE3D
- Has thanked: 67 times
- Been thanked: 130 times
https://www.bhphotovideo.com/c/product/ ... l/overview
Here's one from sony without a lock switch, has a few other durability perks as well.
Not affiliated with sony or bhphoto, haven't bought or used the cards, just providing information that may be helpful to the topic at hand.
- jcoco3
Perfect! My first thought was that is pricey, but its much cheaper than another flight even when the airlines are almost giving them away.
Thanks Tommy.
Thanks Tommy.
- Full Name: Jed Frechette
- Company Details: Lidar Guys
- Has thanked: 62 times
- Been thanked: 219 times
Or you know the scanner could warn you if it's attempting, and failing, to write to a locked disk.
Jed
