Decap
- Full Name: pierrenavarra
- Company Details: Architecture
- Company Position Title: none
- Country: France
- Country: France
Re: Decap
Do not understand, I do exactly the same process of this video!
youtu.be/jo_axNiC1cI
https://www.youtube.com/watch?v=jo_axNiC1cI
- Full Name: Martin Graner
- Has thanked: 160 times
- Been thanked: 175 times
Re: Decap
So decap exe gives me the following help:pierrenavarra wrote: ↑Thu Mar 05, 2020 6:00 pm Do not understand, I do exactly the same process of this video!
DeCap.exe --importWithLicense <output folder> <project name> [options] --contro lFile <control file name>
Uses current Autodesk ReCap License (if available). Create an Autodesk ReCap database with the input scans specified in a control file.
options:
--minRangeClipping <min clipping>
Set the minimum for range clipping. Points located outside the clipping range are discarded.
--maxRangeClipping <max clipping>
Set the maximum for range clipping. Points located outside the clipping range are discarded.
--decimation <decimation value mm>
Set the decimation value which is used to reduce the number of points in your project.
--unify
Enables unification of input scans into a single output scan.
--normalizeIntensity <0|1>
Turn intensity normalization on/off (off = 0, on = 1).
--currentCoordinateSystem <cs>
Coordinate system of raw data to be imported (default is no coo rdinate system)
--targetCoordinateSystem <cs>
Desired coordinate system of resulting project (defaults to cur rentCoordinateSystem if not specified)
Given that you import multiple e57 files, I guess these are with Panoramas?
If yes, I'd assume that the option --decimation is not working, since this is based on an unstructured scan.
Furthermore it is possible that you need to change your calling backslahes to normal slashes (it's a little bit strange with windows and these slashes).
Another thing that might be the issue is that by generating the project once, Autodesk logged you out from your account, so start ReCap and see if you are still in the Pro version at the top.
Good luck.
- Country: France
Re: Decap
Hi , Again, many thx for taking time to help me....I really appreciate.
Still not work!
Look : Here are my folders :
Here is my command LIne :
Here is the result :
I'll go crazy!!!!
Still not work!
Code: Select all
D:\PROGRAM FILES\Autodesk\Autodesk ReCap>decap --importWithLicense "d:\decap\scan0" scan0 "d:\decap\scan0\scan0.e57"
Code: Select all
Welcome to DeCap.exe.
You have provided the following parameters:
--importWithLicense
d:\decap\scan0
scan0
Initializing Licensing. Please wait...
I'll go crazy!!!!
Re: Decap
Looks like your license is not found.pierrenavarra wrote: ↑Fri Mar 06, 2020 2:51 pm
Here is the result :Code: Select all
Welcome to DeCap.exe. You have provided the following parameters: --importWithLicense d:\decap\scan0 scan0 d:\decap\scan0\scan0.e57 Initializing Licensing. Please wait...
Can you start ReCap, and see if at the top there stands ReCap or ReCap Pro?
I think it is only working with the Pro?
Code: Select all
Code: Select all
decap.exe --importWithLicense "d:/decap/scan0" "scan0_RCP" "d:/decap/scan0/scan.e57"
Please delete the folders "temp" and "scan0 Support" prior to starting decap exe.
Rename the e57 to not have the same name as the folder it is in (remove the 0 of scan0.e57).
If I remember correctly I was not able to import multiple e57 files via command and I needed to write the txt file (but you have only one file here).
- Country: France
Re: Decap
Hi VXGrid
Again, thx for answering.
After multiple tests, I've founded the solution!!!! I'm glad to expose it here :
If you want to make a .rcp from list of .e57 (or other format), follow this method :
Here are the conditions to run this process :
- Download the Recap 2017 version from sign-in Autodesk
In fact, this this the Recap 360 2016 version
Why ? Because I tested with Recap PRO 2020, 2019, 2018, and this solution never works!
- Create a directory and stuffs like that
A directory containing all .e57 and a txt file containing the list of all e57 to group and index in the recap file
- on a cmd command and run this command line
Decap will run ...."D:\PROGRAM FILES\Autodesk\Autodesk ReCap 360\decap.exe" --importWithLicense "d:\decap\output" scans --minRangeClipping 0 --maxRangeClipping 200 --decimation 200 --controlFile "d:\decap\list.txt"
After that, the result is the creation of the scans.rcp file with all e57 files indexed
- You must be connected and signed with Recap
- You will find command line informations about decap.exe here : https://knowledge.autodesk.com/support/ ... 1583332497
- Full Name: R K
- Company Details: Iscan3D Expertise Laser
- Company Position Title: Technician
Re: Decap
Hello All
the only way I found out is to use a batch file , via the start command
tldr :
1-asks for input folder
2-asks for output folder
3-creates a full path list of files to decap (liste.txt in the same folder as this natch file)
4-starts the process with the config : --minRangeClipping 0 --maxRangeClipping 120 --normalizeIntensity 1 --decimation 1
5- stays on PAUSE after finishing (to keep cmd window open)
here is the code :
Copy/Paste batch file :
Powershell folders :
Hope this could help ,
PS : dont understand much the "/w /affinity 8" stuff , maybe we could make it better.
tldr :
here is the code :
Code: Select all
@echo off
echo ----------------------------------
echo
set /p INfolder=IMPORTATION:
set /p OUfolder=EXPORTATION :
dir "%INfolder%" /b /s > liste.txt
echo LISTE FICHIERS :
echo --
rem more liste.txt
echo --
@echo NOM DU FICHIER RECAP
set /p id=
C:
cd "C:\Program Files\Autodesk\Autodesk ReCap\"
Decap.exe --version
@echo %date% %time%
start "Decap" /w /affinity 8 cmd /b /c Decap.exe --importWithLicense --minRangeClipping 0 --maxRangeClipping 120 --normalizeIntensity 1 --decimation 1 "%OUfolder%" %id% --controlFile "D:\DECAP\liste.txt"
@echo %date% %time%
PAUSE
Code: Select all
@echo off
echo SELECTIONNEZ DOSSIER D IMPORTATION
setlocal
set "psCommand="(new-object -COM 'Shell.Application')^
.BrowseForFolder(0,'SELECTIONNEZ DOSSIER D IMPORTATION',0,0).self.path""
for /f "usebackq delims=" %%I in (`powershell %psCommand%`) do set "INfolder=%%I"
setlocal enabledelayedexpansion
echo %INfolder%
echo SELECTIONNEZ DOSSIER D EXPORTATION
.BrowseForFolder(0,'SELECTIONNEZ DOSSIER D EXPORTATION',0,0).self.path""
for /f "usebackq delims=" %%I in (`powershell %psCommand%`) do set "OUfolder=%%I"
@echo %OUfolder%
endlocal
echo --
rem more liste.txt
echo --
set /p id=
C:
Decap.exe --version
@echo %date% %time%
@echo %date% %time%
PAUSE
Last edited by [email protected] on Mon Mar 09, 2020 6:31 pm, edited 1 time in total.
- Full Name: Lewis Boxer
- Company Details: Advanced 3D Laser Solutions Ltd
- Company Position Title: Technical Director
- Been thanked: 4 times
Re: Decap
This was a Python Script which was built to run alongside Decap, it would auto build the files required to batch the processpierrenavarra wrote: ↑Thu Mar 05, 2020 6:00 pm Do not understand, I do exactly the same process of this video!
Lewis Boxer
Technical Director
e: [email protected]
w: www.lasersurveying.com
Technical Director
