Black border around mesh
Discuss all Pointfuse related issues here.
IsaacMui
1
Full Name: Isaac Mui
Company Details: Context Architects
Company Position Title: Architectural Graduate
Country: New Zealand
Post by IsaacMui »
Hi all,
I'm having a visual issue when converting point clouds into mesh where the mesh creates a black border around objects. Im wondering if this is an inherent issue with meshes or something to do with the shadowing of meshes and can be altered in settings.
I have attached an example below;
Point cloud:
Mesh:
It affects the visual cleanness of the mesh so would appreciate any help with this.
Mike Deacon
3
Full Name: Mike Deacon
Company Details: Pointfuse Ltd
Company Position Title: Technical Sales
Re: Black border around mesh
Post by Mike Deacon »
Hi Isaac, Thanks for posting.
The blacklines are caused by the created texture being scaled to fit the created model (we'll go offline to explain in a bit more detail).
To create a more visually pleasing mesh, you can flip to the "advanced" settings during the mesh model creation, and lower the "Maximum Supertile Size" to a lower value (default is 1000mb, try 250mb). This will produce more texture files and so create a cleaner result overall.
I'll drop you a message offline to get a workflow demonstration set up.
Thanks again,
Mike
Return to “Pointfuse”
