Hello, how much is your bigger project? We have finished last week one project of scanning historical railway station in Prague (Praha Hlavní nádraží - https://goo.gl/maps/5ghb1F9LM1z2yD3M6) and we have 1847 scans with 1,9 bilion (1 900 000 000) points of pointcloud. And we are experienced of limitations of RealWorks. With this number of scans is RealWorks lagging and not responding. Our workstation have 128 GB RAM, 3,7 GHz XEON, two 240 GB SSD drive in RAID (system) and two 2TB drive for data.
I don't know if will help increase of pagefile or another tweak of system.
Maximum number of scans
- Full Name: Jared
- Skype Name: jaredmatthews
- Has thanked: 5 times
- Been thanked: 13 times
Re: Maximum number of scans
Try break the project down into smaller chunks.
You no not need ALL stations always loaded in when registering.
Once you have registered (for example the externals), you can export that cloud, leave in a few connecting scans for the internals, and then start registering the internal scans.
This way your PC doesn't have to struggle and constantly try to display billions of points
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Don't know much about real works, but the following is worth checking in terms of hardware.JkX7 wrote: ↑Thu Jul 02, 2020 8:37 am Hello, how much is your bigger project? We have finished last week one project of scanning historical railway station in Prague (Praha Hlavní nádraží - https://goo.gl/maps/5ghb1F9LM1z2yD3M6) and we have 1847 scans with 1,9 bilion (1 900 000 000) points of pointcloud. And we are experienced of limitations of RealWorks. With this number of scans is RealWorks lagging and not responding. Our workstation have 128 GB RAM, 3,7 GHz XEON, two 240 GB SSD drive in RAID (system) and two 2TB drive for data.
Your system seems a few years old and it is probably worth seeing where the bottleneck is. If you run task manager while the system is lagging, you can see which component is causing the problem. If you have a eight core processor and the CPU is constantly close to either 12.5% or 100% your program is CPU bound (12.5% single threaded = 100/8, 100% multi-threaded). Same for disks and GPU. If the bottleneck is disk, it is a reasonably cheap and easy upgrade to to get newer faster SSD drives which could be a big improvement. Same for GPU, a bit more expensive but an easy upgrade. If you're CPU is showing 100%, a new CPU with bigger core count would help a lot but could be a major upgrade or even new workstation. CPU showing 12.5% (or 100 / number of cores) suggests you'd get the best performance upgrade by moving to a software solution that was properly multi-threaded.
Personally, on that workstation, I'd swap out the old SSDs for faster 1TB models anyway. You shouldn't really need any swap file with 128gb RAM on a 1.9 billion point cloud, but if you do this will show up as disks hitting 100% on the performance tab. As Jared has said above, the best solution could be modifying your workflow to deal with smaller amounts of data in memory at any one time.
- Full Name: Martin
- Company Details: GEO Development
- Company Position Title: Laser scanner manager
- Country: Latvia
Only problem is your ssd. You must upgrade to m.2 with pci express 4.0. The fastest possible. I use trw for 5 years and as i see the hard drive speed is most important factor. I had 2100 scan project. When use ssd it hangd up, after intaling m.2 disk, i get to result.
- Full Name: Jiri Krejci
- Company Details: DiGiTry Art Technologies
- Company Position Title: SEO - Photogrammetry and laser scanning
- Country: Czech Republic
- Been thanked: 2 times
Thank you all for reply. main problem seems to be slow harddrives and we are swapping to new pair of ssd. Our workflow is to assemble floor, stairs, exterior in chunks which are join together for georeferencing.
- Full Name: Pavel Grée
- Company Details: XGEO
- Company Position Title: executive one
Have similar problems with 1000+ scans in RW. Help: SSD RAID0(cheap-fast), resection-best when RW start freezing, hide part you do not need. PG.
