"I don't use TruView much, but when I do, it fails." Typically I'm a WebShare guy.
TruView is up-to-date, just re-installed to be sure. IE is up-to-date as well, and is set to allow Active Content. Screen is incorrect and when I enter a scan word, it crashes. Attached screenshot.
TruView won't run; Crashes IE each time
- berdindc
- Full Name: Dan
- Company Details: Berding
- Company Position Title: Project Engineer
- Full Name: Bruce Yager
- Company Details: Rikore Geomatics
- Company Position Title: Department Head
- Been thanked: 7 times
Re: TruView won't run; Crashes IE each time
I would check your security software. Ours has to be turned off to allow Tru-View to run.
Under IE options go to advanced.
Select under browsing "Enable Third Party Browser Extensions"
Security "Allow Active Content to run in files on My Computer"
Both need to be checked.
Hope this works.
Hope this works.
- berdindc
- Full Name: Dan
Thanks for the suggestions, unfortunately did not work. Tru-View has been around +5 years, seems like these issues should be not be issues by now.
- colhum1
- Full Name: Colin Humphreys
- Company Details: Warwickshire Police
- Company Position Title: Forensic Collision Investigator
- Skype Name: col.humphreys
Dan....
I'm sure you've seen this but if not:
https://laserscanningforum.com/forum/vi ... =25&t=7702
or
http://www.ollerhead.ca/troubleshooting/
Colin
or
Colin
"Just leave me alone. I know what I am doing" - Kimi Räikkönen
- colhum1
Glad to help.berdindc wrote:Thank you! That was the issue, works again!!
Colin
