EdgeWise DPI-8 Webinar data-set processed in InfiPoints
Discuss DotProduct hardware here.
TommyMaddox
Full Name: Tommy R Maddox III
Company Details: ONSITE3D
Company Position Title: Director of Technology
Has thanked: 67 times
Been thanked: 130 times
Post by TommyMaddox »
youtu.be/3fZGyNogDBY
InfiPoints offers direct import + extraction of the scans produced by the DotProduct DPI-8 Scanner. They also offer "InfiPoints on a Tablet" for the use of in-field automatic feature extraction on the same tablet that the DPI-8 uses.
This particular data set was the one captured in the EdgeWise DotProduct DPI-8 Webinar on September 15th, 2016
I've processed the data in InfiPoints, and applied some minor corrections to show how easily the data can be handled.
NOTE: The screen wobbles rapidly during this demo. For some reason this only happens when I run the screen capture software I'm using, so it really is a much more fluid experience in person.
Time Metrics:
Import with Extraction of Pipes and Planes: 2 minutes and 3 seconds
(Pipes and Plane export took 3 seconds)
Manual cleanup: approximately 10 minutes. Would have been quicker with practice and without the screen wobble issue experienced when recording.
I had practiced once before, and found that using noise-reduction features in InfiPoints on this somewhat sparse data-set resulted in a bit more difficulty finishing out the piping, so in the video, you'll notice I opted not to run the noise reduction.
You'll also notice the method of assigning all of the points (+ clearance range) attributed to pipe group or groups onto its own layer for further processing or interference checking.
Shunshun1209
Full Name: Shun Higashide
Company Details: Elysium Co. Ltd.
Company Position Title: Global Business Analyst
Country: Japan
Re: EdgeWise DPI-8 Webinar data-set processed in InfiPoints
Post by Shunshun1209 »
Hi Tommy,
This is an interesting case as I personally saw the webinar recording and was curious about how the process
would take place in InfiPoints.
Thank you very much for giving this a try and making a video of it.
By the way, the product where InfiPoints feature extraction runs on the DPI-8 is called "InfiPoints DP"
Return to “DotProduct”
