Bad Quality Istar Coloured Orthophotos in Scene
- Full Name: Jaap Bijlstra
- Company Details: Scan360
- Company Position Title: Projectmanager-Engineer
Dear Readers,
with Colourcloud V1.10, I coloured Faro Scans of a Church with iSTAR Panoramas. However when I export Orthophotos in Scene the quality of the Photos is bad. My question is: what did I do wrong in the process from colouring the Scans till exporting the orthophotos in Scene?
In colourcloud I tried the 3 options from iSTAR Equirectangular(PNG) but still I have black lines in my Faro View.
In the attachment I put one Orthophoto and the View in Faro Scene
. I hope someone can solve my Problem.
Thanks,
Jaap
Thanks,
Jaap
- Full Name: Bruce Yager
- Company Details: Rikore Geomatics
- Company Position Title: Department Head
- Been thanked: 7 times
Re: Bad Quality Istar Coloured Orthophotos in Scene
Jaap,
Try running the photos through iStar's Immersive Studio first, then import them into Scene.
- I have made 30-40 posts
- Full Name: Andrew Baddeley
- Company Details: Terra Visus Ltd
- Company Position Title: Chief Operating Officer
- Country: Scotland
- Skype Name: badders
How did you position iSTAR relative to the scanner head on the tripod?
Hello Bruce,
Thank you for the reply. I generated all the Panoramo fotos in Jpeg Format. However i don't get what the NCTech Colourcloud Software generates with the JPEG File. In the Log file I only see that the .nctri File is used to Colour the Pointcloud.
Regards Jaap
Regards Jaap
Hello Andrew,
I changed the height of my Scanner tripod around 40mm when I fixed the Istar.
- Country: Scotland
So did the tripod move between taking off the scanner head and attaching the iSTAR camera?jbijlstra wrote:Hello Andrew,
Hello Andrew,
Thank you for the reply. It is possible that the tripod moved with exchange from scanner and Istar. But can that be the reason of the Orthophoto quality. Because in every seperate scan the colouring looks good especially when I export from for instance 8 scans in a clippingbox it happens. When I have less scans, the quality is a better. I attached another orthophoto somewhat better. Regards Jaap
- flohrd
- Full Name: Daniel Flohr
- Company Details: FARO
- Company Position Title: VP of Software Engineering
Seems like you are visualizing individual scans rather than having one unified data set.
Try to create a project point cloud with color balancing activated. Also activate the duplicate points filter.
This should remove most of the visual clutter.
Hello Daniel,
that solved the issue! Thank you a lot. In the attachment is visible how the orthophoto looks with using the project point cloud option with the filters.
Regards Jaap
Regards Jaap
