3d Modelling of a church
- graham.watson
- Full Name: Graham Watson
- Company Details: Road Science
- Company Position Title: Technical Lead - High Speed Data
- Country: New Zealand
We have been asked to look at scanning an old wooden church. As well as the pointcloud data the client has expressed an interest in creating a 3d model of the structure. What would people suggest as the best software to produce this. We would use a Faro scanner and Scene to register. Any advice appreciated
Graham
Graham
- richard_m
- Full Name: Richard Merrin
- Company Details: Fugro
- Company Position Title: Data Processor _ Project Engineer
- Country: Netherlands
Re: 3d Modelling of a church
Hi Graham,
Failing that, it really comes down to deliverables. Beware the vague Client specification - always ends badly if you allow the Client to refine their spec as they figure out what they need during or after the scanning. If you can figure out what your Client wants the data for, i.e. BIM / Engineering / Architecture / Pretty marketing / etc, then we can work it backwards and suggest the best software and you can write the spec for your Client to agree.
Regards
Richard
I'd suggest the suite of software posessed by your local survey/scanning contractor is the best software to produce this.graham.watson wrote: What would people suggest as the best software to produce this.
Regards
Richard
- Mike Annear
- Full Name: Mike Annear
- Has thanked: 122 times
- Been thanked: 196 times
Hi Graham,
The cheapest, most versatile, most compatible, 3D modelling software package capable of importing point-clouds is Rhino 3D.
The guys from Digital Surveys recently posted this;
( http://laserscanningforum.com/forum/vie ... =94&t=7262 )
I have been using Rhino for about 14 years, it has a vast array of plugins for everything from piping to footware
It is all about the deliverable, beware of anyone who tries to sell you a more expensive option
The attached pics are Rhino 3D models (rendered in 3ds Max) that I made of the Sydney Harbor Bridge from Riegl scans about 10 years ago....
Cheers,
Mike.
Cheers,
Mike.
- Mike Annear
I just found some Church 3D feature modelling I did from a few years ago, done in Rhino 3d,
Mike.
Mike.
- Peyman Bashiri
- Full Name: Peyman Bashiri
- Company Details: Aero Geometrics Canadian Z+F reseller
- Company Position Title: Laser scanning and BIM Specialist
- Skype Name: pbashiri2003
- Has thanked: 56 times
- Been thanked: 40 times
if your client is an architect , then the most logical choice would be Revit.
Be careful for the LOD they might expect , there is a pdf file we use here for it.
http://bimforum.org/wp-content/uploads/ ... cation.pdf
If you need help give me a shout , we can generate the model .
Peyman
Peyman
- Full Name: James Still
- Company Details: BIM Technical Manager
- Company Position Title: BIM Technical Manager
- Has thanked: 4 times
- Been thanked: 10 times
it can be done in Revit, but depending on LOD and deviation agreed with the client, massing for some elements may be the only option which will result in a very large Revit file.
the key is to determine what the clients end requirements are for the model ie visuals, BIM
- Full Name: Michael Axiotis
- Company Details: Veris
- Company Position Title: Veris
Hi All,
The answer I am looking for is probably No! However I will ask the question. Is there a Plug-in for Rhino5 that is as good as PoinTools for Rhino was/is (That is if you still have a copy)?
I have been looking at Sycode who have PointCloud for Rhino, but has this got the capability of slicing PointClouds to Model Structures instead of Draping/Meshing? Anyone used this before?
Michael
Michael
- I have made 60-70 posts
- Full Name: Tejeswar Devu
- Company Details: COWI INDIA Private Ltd
- Company Position Title: Project Manager-Geoservices
- Country: India
- Skype Name: teja.devu
[quote="graham.watson"]We have been asked to look at scanning an old wooden church. As well as the pointcloud data the client has expressed an interest in creating a 3d model of the structure. What would people suggest as the best software to produce this. We would use a Faro scanner and Scene to register. Any advice appreciated
Hello Graham,
I would suggest you to use CYCLONE to model the structures and import the COE into Autocad.
Hope this may help you.
Hello Graham,
Tejeswar.Devu
Tejeswar.Devu
- Full Name: Vijay Pinglay
- Company Details: New company
- Company Position Title: Production Manager
- Country: India
- Skype Name: vijay.pinglay
Hello Graham
There are many software's, you could use by as as Peyman Bashiri mentions, you may need to ask the level of detailing required by the client. I guess Rhino uses commands that are compatible with Autocad is much easier to use
regards
Vijay
regards
Vijay
- Full Name: Stefan Wachsmann
- Company Details: scantaxi.de
- Company Position Title: supervisor
Hi Graham.
the main question I think is what will the client do with your model!? And what skills do you have in modeling?
If it will be used for visualization rhino, maya, max, C4D will be fine, depending on the target software! In my opinion it is necessary to model in the destination software!
If you need a architecture model, ask for the destination software too! Most parts will be difficult to be transformed from Revit to Archicad or something else... Rhino and Autocad
Gesendet von meinem iPhone mit Tapatalk
