Hardwarerror3 on a HDS6200
Faro FOCUS S350, S150, S70, M70, X30, X130, X130HDR, X330, X330HDR. Leica RTC360, C10, P15, P20, P30, P40, P50, BLK360, HDS6*00, HDS7000,HDS8800, HDS8400. Riegl VZ6000, VZ4000, VZ2000, VZ1000 & VZ400i. Topcon GTL-1000, GLS2200, GLS1500. Trimble X7, X9, X12, SX12, SX10, TX8, TX6, S7 & S9. Z+F IMAGER 5016, 5010X, 5010C, 5006H, 5006EX & PROFILER 9012
christopherbyrne18
15
Full Name: Christopher Byrne
Company Details: Murphy Geospatial
Company Position Title: Head Of Dept Special Projects
Has thanked: 9 times
Been thanked: 19 times
Post by christopherbyrne18 »
Can anyone shed some light on the Hardwarerror3 on a HDS6200?
I've seen a post about a Hardwareerror2 on a 6100. This is a lightly used instrument that hs been in storage for a quite a while.
Chris
mzsofi
Full Name: Zsófia Magyari
Company Details: Széchenyi István University
Company Position Title: junior assistant professor
Country: Hungary
Re: Hardwarerror3 on a HDS6200
Post by mzsofi »
I work with the same instrument and report the same error after switching on. Has anyone found a solution to this problem? According to Hungarian support it is not worth it to send it to Germany. This is really sad.
Regards
Zsófi
PaoloDP
1
Full Name: Paolo Del Ponte
Company Details: Ivicom
Company Position Title: designer
Country: Croatia
Skype Name: pdponte
Post by PaoloDP »
Hi, any update about that issue? I got same error on our HDS6200. I know it is a very old scanner but it was working and we used it till now.
RThomasC_360
1
Full Name: Warnier Thomas
Company Details: Leica-Geosystems
Company Position Title: Technical Support Engineer 3D-Beginner
Post by RThomasC_360 »
Hi !
Try to reboot. Had a thing like this with a P30...Drive was Dead.... SSD down
If its frozen.... call Leica Support...
Does it usually controlled by Leica?
PaoloDP
1
Country: Croatia
Skype Name: pdponte
Post by PaoloDP »
How do you mean reboot? I have tried on/off serval times, tried with different battery, even disassembly front cover to see MBO, nothing suspicious there. I even flash the BIOS by removing the RAM. I am also thinking that something happen with HDD or SSD. It has one 4GB Flash card inside, error is the same even when I remove it.
Is there any way to connect it to external monitor, because I see on MBO there is a VGA port and PS2 for keyboard? Anyone tried?
It was not controlled in Leica last 8 years :) I already call local Leica office, but they said that it is not worth to send it to service. It is too old.
cpw006
16
Full Name: Chris Widmer
Company Details: KCI
Company Position Title: 3D Scanning Manager
Has thanked: 3 times
Been thanked: 8 times
Post by cpw006 »
Contact Z+F and see if they are willing to work on it or with you. We had an older HDS6100 that Leica stopped servicing and we were able to send it to Z+F-USA to get calibrated and serviced. We used them to support this model until we traded it in a few years ago.
cpw006
16
Post by cpw006 »
cpw006 wrote: Tue Jun 07, 2022 12:45 pm Contact Z+F and see if they are willing to work on it or with you. We had an older HDS6100 that Leica stopped servicing and we were able to send it to Z+F-USA to get calibrated and serviced. We used them to support this model until we traded it in a few years ago.
The HDS6000 series scanners are a Z+F product rebranded by Leica.
tariqalmurri
Full Name: TARIQ MOHAMAD HASAN
Company Details: Diwan
Country: Egypt
Post by tariqalmurri »
I had the same problem, and it was solved by replacing the bios battery with new one and it will work fine again
