Whilst doing a visual alignment of two scans I cant seem to change the side view when I move in the z-axis.
I can orbit around completely whilst in side view however when I come to move the cloud data it switches back to the original side view.
In the field app it works great and I can move data in the z-axis in any view I choose. Just not sure if I am missing something in Register as I cant imagine it isnt a feature.
Changing side view in Register
- Full Name: Lee Whiteman
- Company Details: Whiteman Architects
- Company Position Title: Whiteman Architects
- Country: United Kingdom
- Forum Supporter
- 1
- Full Name: Kruse
- Company Details: HPCC
- Company Position Title: Lead VDC Engineer
- Has thanked: 20 times
- Been thanked: 38 times
Re: Changing side view in Register
When adjusting the elevation relationship between point clouds, you have to use the pan tool to make that adjustment at which point it will force you back into the elevation view and pull you out of the free orbit view. That's by design.
You can select the rotation tool and when using that in the visual alignment for elevation view, it'll rotate the point cloud to give you a better view. It won't however allow the vertical relationship to change between the two clouds. You'll have to reselect the pan tool to adjust the elevation from one cloud to the next.
- JoshSteinert
- Full Name: Joshua Steinert
- Company Details: HFA AE
- Company Position Title: ScopeScan Lead
- Has thanked: 4 times
- Been thanked: 2 times
Orbit in Side View used to snap to a orthographic view near the orbited view.
Now, when you select the move tool after Orbit the view will return to last orthographic view.
Using the Rotate tool in side view is the only way to achieve workable rotated side views.
I would like an accelerated rotation, because it is painstakingly slow to rotate in side view.
Ah thanks for the replies. For some reason it didnt occur to me to use the rotate tool! I assumed that would rotate the one of the setups like the move tool does. This is exactly what I was after!
Thanks again
Thanks again
- gsisman
- Full Name: Steve Long
- Skype Name: gsisman1
- Has thanked: 452 times
- Been thanked: 97 times
I agree, maybe a switch to make ALT key an accelerated rotate in this view, the way ALT make it superfine adjustment in the Ortho-Align viewJoshSteinert wrote: ↑Fri Jan 20, 2023 3:25 pm Orbit in Side View used to snap to a orthographic view near the orbited view.
