Hello !
I'm looking for new PC to process and register in FARO scene.
I have FARO FUCOS S70
What Hardware you recommend for that?
looking for new PC
- 1
- Full Name: Shahar
- Company Details: BIM
- Company Position Title: Scanner
- Country: ISRAEL
- Jason Warren
- Administrator
- Full Name: Jason Warren
- Skype Name: jason_warren
- Has thanked: 443 times
- Been thanked: 246 times
Re: looking for new PC
Please take a look at the thread viewtopic.php?t=10388...
Co_Founder
LaserScanningForum
Co_Founder
LaserScanningForum
- Leandre Robitaille
- Company Details: Cima+
- Has thanked: 61 times
The thread Jason shared dates from 2021 so I will just let you know what I think you should get in 2023:
CPU : Get a 13900k from intel for CPU. You want the fastest single core as possible over multithread, no need to go for Threadripper, the 13900k has a very respectable multithread speed for a fraction of the price of threadripper.
**note that the single thread speed is the most important thing for Scene, everything else(ram speed, gpu, ssd speed, multi thread, etc) is second.
RAM : Max what the CPU allows, hence get 128gb of ram. Get the fastest ram your budget allows, ECC as well if possible (its supported)
GPU: Get a random graphic card. Don't need much GPU for Scene or anything TLS pointcloud related. If you want to stay in the professional line up get a RTX 4000 Quadro
STORAGE: Normally I would say get a raid0 of 4x2tb nvme with the nvme raid adapter, but the 13900k only has 20 PCI lanes. Hence aim more toward a dual nvme setup (make sure your motherboard has at least 2 on board m.2 nvme);
a 2tb nvme ssd for local C: (windows + softwares)
and a second nvme ssd of 4tb (data) for projects.
A built like this should be reasonably affordable. You will have to pick the parts for the case/motherboard/cooling but maybe just let your IT team know the key components you want, as the ones I stated above, and they will fill in the blanks. Otherwise I would look into https://pcpartpicker.com/list/ and built it from there, this website allows you to check for compatibility issues.
I went and built one quickly for fun and it came up to 5120.40 Canadian $ (or if I look up USD its $3769.86)
https://ca.pcpartpicker.com/list/Yk26fv
I would honestly involve your IT team for this however, you will have to shop for the best deal for your country, pc partpicker lets you know where to buy and the best price for each parts, most the parts I picked are not available for Israel. The pcpartpicker website might not have access to all the local places where you can buy pc parts in your country, hence why involving your IT team is a good idea.
I tried building one for Israel but I couldn't find a power supply (might be some law blocking this) and I had to change a lot of the components to even be able to have a working pc https://il.pcpartpicker.com/list/VQXV8r
- I have made 60-70 posts
- Full Name: Dustin Manning
- Company Details: luxpoint
- Has thanked: 17 times
- Been thanked: 13 times
I think the 13900ks just got released. I'd go with that. Get a ddr4 motherboard with 64-128gb of RAM. A 3070 would be totally adequate. If you build yourself you can do it for around $2k.
- 1
- Full Name: Shahar
- Country: ISRAEL
Leandre Robitaille wrote: ↑Thu Jan 12, 2023 10:35 pm The thread Jason shared dates from 2021 so I will just let you know what I think you should get in 2023:
This is what the local store offer to me
https://www.yahavpc.co.il/build?id=RLMVRY0TSJV2Y3
If you have recommended changes ..
Thank you all!
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Personally, if budget allowed, I'd swap the 2 x 2TB nvme for 2 x 4TB nvme and add a 10TB hard drive. Point clouds just seem to eat up space, particularly if you're also capturing HD images.Shahar10 wrote: ↑Mon May 08, 2023 2:24 pm
Thank you all!
- ProCro
- Full Name: Nino Skupnjak
- Company Details: SKIMI64
- Company Position Title: procurator
- Country: Croatia
- Has thanked: 7 times
- Been thanked: 30 times
unofficially by cpu, and officially by mbo vendors you can have 192GB of ram (48gb dimms)
eg. https://www.asus.com/motherboards-compo ... /techspec/
I would rather have one 1TB nvme for OS, apps and temp/cache, one larger nvme (4TB) for processing, and 2 12+TB raid 0 for backup (or proper NAS).
