Dear all,
Is there a way I can split the face of the step from its underside?
https://drive.google.com/file/d/1_Jcw11 ... sp=sharing
https://drive.google.com/file/d/1YNNFLJ ... sp=sharing
Split Face of Step form underside
- I have made 100> posts
- 3
- Full Name: Nicolas LANDRIVON
- Company Details: Technodigit
- Company Position Title: Sales and Support
- Country: France
- Been thanked: 48 times
Re: Split Face of Step form underside
Hello
Just to be sure, something like that ?
Regards
Nicolas L
Regards
Nicolas L
- Forum Supporter
- Full Name: Clive Bugeja
- Company Details: ARC International Surveyors Ltd.
- Country: Malta
- Has thanked: 8 times
Hi Nicolas,
Yes exactly. Can you explain in brief how you finished up with this result?
- 3
- Country: France
The method that I used:
- Building extractor (manual and semi-automatic extraction of the top side of each step)
- I grouped all separated mesh to make a compound
- I separate the compound mesh from the cloud using a distance (for instance 5 cm) - Clean Separate with...
PS: create a suitable UCS if necessary beforehand (like Wall + Wall).
Another way if you want to keep the top steps with the rest of the cloud but without the downside part:
- create a quick mesh (Scan to mesh)
- Separate the bottom side of the stairs, use Clean Separate in the Surface modeling menu (camera position -Z and select the option back, only visible triangles according to the normal direction of the created mesh)
- Keep cleaning the mesh if necessary to focus on the main part
- Smooth
- Separate the point cloud with the mesh (5 cm for instance)
Regards
Nicolas L
- Smooth
Regards
Nicolas L
- Forum Supporter
- Country: Malta
Hi Nicolas,
Appreciate your reply. Will try it out and let you know how it goes.
