How can I view my point clouts in Meta Quest 2 ?
- LPaulCook
- Full Name: L Paul Cook
- Company Details: Land surveyor doing LiDAR
- Has thanked: 47 times
- Been thanked: 44 times
I can view my scans in the older wired Oculus Riff VR headset. Very Cool too! Just like being on site again! But it must be wired to my laptop which is very restrictive and cumbersome to use.
Can I create a file and upload it to the newer Meta Quest 2 and view my projects without the wire limitations for the older Oculus Riff headset?
Thanks for your help with this.
L. Paul Cook, PLS
www.LPC3D.com
www.LPC3D.com
- pburrows145
- Full Name: Paul Burrows
- Has thanked: 109 times
- Been thanked: 123 times
Re: How can I view my point clouts in Meta Quest 2 ?
Leica TruView VR now works with Meta Quest 2 in cabled mode... if that helps?
- Bohdan gutnyk
- I have made 40-50 posts
- Full Name: Bohdan Gutnyk
- Company Details: 3dm company in kiev
- Company Position Title: 3dm
- Country: Ukraine
- Skype Name: bohdangutnyk
- Has thanked: 15 times
- Been thanked: 45 times
I tried using Faro Scene Lite(free version) to stream point cloud to my oculus quest 2.
It has quite comfortable controls and works quickly
Works well wirelessly also, but you still need your laptop to stream content over WI-FI.
- Full Name: julien A
- Company Details: historic preservation
- Company Position Title: intern
- Country: france
- Been thanked: 2 times
I tried this morning to use Quest2 with Truview VR but it does not launch, even if the device is connected to the laptop.pburrows145 wrote: ↑Wed Dec 07, 2022 4:17 pm Leica TruView VR now works with Meta Quest 2 in cabled mode... if that helps?
The project is VBR ready and the button is enabled, a pop up messages says it's launching but nothing happens...
I read the comments on this youtube page, but nothing helps.
https://www.youtube.com/watch?v=ujCL6H2SLh4&t=3s
Any clue ?
- pburrows145
I suggest you please contact local support... I have not seen this before.
Also check that anti-virus is not blocking the exe.
And I assume both STEAM VR and Windows MR are working correctly...?
- Country: france
Thanks Paul, I will contact them.
After reading posts, I did install Steam and MR but I don't see the point of having them since they are not related to Quest.
- LPaulCook
How do you stream content over wifi?Bohdan gutnyk wrote: ↑Thu Dec 08, 2022 8:21 pm I tried using Faro Scene Lite(free version) to stream point cloud to my oculus quest 2.
Thanks for your help.
L. Paul Cook, PLS
www.LPC3D.com
www.LPC3D.com
- Bohdan gutnyk
- Country: Ukraine
Oculus Quest 2 has a wireless streaming feature for streaming content from a PC called the Oculus Air link. You can find instructions on YouTube on how to activate it.LPaulCook wrote: ↑Wed Jan 25, 2023 8:09 pmHow do you stream content over wifi?Bohdan gutnyk wrote: ↑Thu Dec 08, 2022 8:21 pm I tried using Faro Scene Lite(free version) to stream point cloud to my oculus quest 2.
Then you need to have the Oculus app and Steam VR installed on your PC
After you activate the air link on your Quest 2, start the Steam VR on your computer, minimize it, and go to Faro Scene. There you will need to open your point cloud project and select VR button
- ScottKarlins
- I have made 50-60 posts
- Full Name: Scott Karlins
- Company Details: Engineering Systems Inc.
- Company Position Title: Technology at Large
- Skype Name: ScottKarlins
How did you do this? Were you able to get FARO Scene into VR mode to the Quest 2?Bohdan gutnyk wrote: ↑Thu Dec 08, 2022 8:21 pm I tried using Faro Scene Lite(free version) to stream point cloud to my oculus quest 2.
Thank you!
Scott Karlins
Technology at Large
FARO Certified Trainer
(678) 990-3280 ext. 6025 Fax: (678) 990-3285 Mobile: (770) 338-9946
http://engsys.com
Technology at Large
http://engsys.com
- Bohdan gutnyk
- Country: Ukraine
You need to have Steam VR installed on your computer. Launch it and make sure the helmet and controllers are connected to your PC and visible on Steam VR app. After that, launch Faro Scene and select the VR mod in the top panel.
I've already sold my helmet, so unfortunately I can't make a more detailed instruction, hope this helps.
