Hello everyone,
I've got a question in regards using my Surphaser 100 HSX and Surphexpress software to identify spherical targets. While performing a scan I would like to have targets situated around the object I'm scanning to make point cloud conversions easier using xor and geomagic software. I see there is a target reference tab but I'm unsure how to go about identifying the targets in each scan. Should I perform a preview scan each time, highlighting each target then performing the more detailed scan? Is there a better method to perform this scan because the preview scan idea does not seem to work out how I wish it would. If anyone has any recommended methods to performing a scan while using spherical targets I would appreciate your feedback! Thank you...
Surphexpress and Targets
- Full Name: Brett McCarrier
- Company Details: MacB
- Company Position Title: Technician
- Full Name: Stephen Strand
- Company Details: Self-Employed
- Company Position Title: Seeking Scanning Opportunities
Re: Surphexpress and Targets
Just run through the scan normally (either preview, sector, or full volume), then you have to "pick" the targets from the target tab after the scan has been processed. Sometimes, based on what size spheres you are using, you really have to hone in your search settings, or you will get no targets, or a ton of false positives. You could just use the ProcessC3DShell program too, much faster that way. We typically use the plate targets, and then export the targets file for each scan as a .txt file, then export each scan file as .ptx, then use third party software to align.
Hope this helps!
-Stephen
Hope this helps!
-Stephen
- Full Name: Adrian Haarbach
- Company Details: Siemens
- Company Position Title: Research Scientist
What third party software do you use to align the scans using the extracted marker's txt files?
- Full Name: Martin Berryman
- Company Details: Wanes Custom Woodworks
- Company Position Title: Manager
As noted, ProcessCD3Shell (from Basis - the parent company behind Surphaser) is the most automatic way to find targets and align scans. Contact the vendor you bought the scanner from for help. In rough terms, you create a marker file for your anchor / base scan, then align all of the other scans to that scan. Once aligned, filter and sample the data in Geomagic Design X, then import the filtered and sampled results into Design X, combine the scans, and align them interactively using the on-board level sensor to create your primary plane. I don;t want to sound like their advertyising rep, but the team at Rapid3D in Calgary, Alberta in Canada can provide training on the Surphaser and related software, as well as all of the Geomagic products. No affiliation, just a happy customer.
- I have made 30-40 posts
- Full Name: Akram Mousa
- Company Details: ReCreate3D
- Company Position Title: Founder
- Country: UAE
- Has thanked: 3 times
- Been thanked: 3 times
Why don't you use ProcessC3Dshell instead of exporting to a third-party software?Stephen.Strand wrote: ↑Wed Jul 19, 2017 8:40 pm Just run through the scan normally (either preview, sector, or full volume), then you have to "pick" the targets from the target tab after the scan has been processed. Sometimes, based on what size spheres you are using, you really have to hone in your search settings, or you will get no targets, or a ton of false positives. You could just use the ProcessC3DShell program too, much faster that way. We typically use the plate targets, and then export the targets file for each scan as a .txt file, then export each scan file as .ptx, then use third party software to align.
Hope this helps!
-Stephen
