Any caveats when combining terrestrial scans from two different manufacturers? We have a Faro S series and an X7. The seems to have similar accuracy (2mm).
we have a larger job coming up and want to split the scanning to save time on the field.
Combining scans from different manufacturers
- Full Name: C-Augusto
- Company Details: 3d scanning
- Company Position Title: USA
- Country: US
- Has thanked: 39 times
- Been thanked: 3 times
- landmeterbeuckx
- Full Name: Lieven Beuckx
- Country: Belgium
- Has thanked: 103 times
- Been thanked: 325 times
Re: Combining scans from different manufacturers
When i combine riegl with tx5 (faro) i just scan some spheres with the Riegl, extract the center coordinates from Riscan and import that in Faro Scene.Augusto 3D wrote: ↑Thu Jun 23, 2022 5:30 pm Any caveats when combining terrestrial scans from two different manufacturers? We have a Faro S series and an X7. The seems to have similar accuracy (2mm).
I'll export both datasets and import them in Pointcab for 1 nice combined dataset.
I'm sure the X7 software knows how to calculate the center of a sphere as well.
- Country: US
interested to learn more about your workflow. So you bring the sphere centers as control points into Scene ? I mean you should be scanning the same speheres with both scanners no?landmeterbeuckx wrote: ↑Thu Jun 23, 2022 7:22 pmWhen i combine riegl with tx5 (faro) i just scan some spheres with the Riegl, extract the center coordinates from Riscan and import that in Faro Scene.Augusto 3D wrote: ↑Thu Jun 23, 2022 5:30 pm Any caveats when combining terrestrial scans from two different manufacturers? We have a Faro S series and an X7. The seems to have similar accuracy (2mm).
PointCab is nice, I wish they had some better extraction tools because in terms of rasterizing scans, nothing beats it.
- landmeterbeuckx
- Country: Belgium
Of course i scan the same spheres with both scanners. In Riscan incan extract the center of a sphere. I import that in SceneAugusto 3D wrote: ↑Thu Jun 23, 2022 8:17 pminterested to learn more about your workflow. So you bring the sphere centers as control points into Scene ? I mean you should be scanning the same speheres with both scanners no?landmeterbeuckx wrote: ↑Thu Jun 23, 2022 7:22 pmWhen i combine riegl with tx5 (faro) i just scan some spheres with the Riegl, extract the center coordinates from Riscan and import that in Faro Scene.Augusto 3D wrote: ↑Thu Jun 23, 2022 5:30 pm Any caveats when combining terrestrial scans from two different manufacturers? We have a Faro S series and an X7. The seems to have similar accuracy (2mm).
- smacl
- Has thanked: 402 times
- Been thanked: 413 times
Intensity returns from different instruments can be very different. Ranges vary and can be linear or logarithmic. Can make drawing using Intensity on the combined mode a bit of a pain.
- Full Name: Simeon Herrod
- Has thanked: 43 times
- Been thanked: 69 times
We've recently done a job that combined data from a Faro S150, NAvVis VLX, Emesent Hovermap and DJI M300/P1.
All went together without a problem as our survey control was good.
- Country: US
