Key Plan not aligned with scan
Discuss Autodesk ReCap Studio software here.
boxel0
8
Full Name: Lewis Boxer
Company Details: Advanced 3D Laser Solutions Ltd
Post by boxel0 »
Hi All,
We have created recap files from importing .fls files into Recap, but have noticed that after the import and indexing everything is fine and aligned,
But when we re-open the recap .rcp file the key plan doesn't align with the mirror balls; has anyone else seen this before?
Lewis Boxer
Technical Director
e: [email protected]
w: www.lasersurveying.com
mikajahkola
I have made 70-80 posts
4
Full Name: Mika Jahkola
Company Details: Myymore Oy
Country: Finland
Has thanked: 11 times
Been thanked: 13 times
Re: Key Plan not aligned with scan
Post by mikajahkola »
You are not alone with this problem. I have seen it once with the new Recap version, mostly it works right.
BTW, when I imported this particular rcp point cloud to Autocad, the registration was completely lost and all scans were centered at the origin.
boxel0
8
Post by boxel0 »
Since upgrading to 2023 this issue has been fixed
Lewis Boxer
Technical Director
Peyman Bashiri
12
Full Name: Peyman Bashiri
Company Position Title: Laser scanning and BIM Specialist
Skype Name: pbashiri2003
Has thanked: 27 times
Been thanked: 25 times
Post by Peyman Bashiri »
There is an option to write the scan location (Geo referenced or local) into scan header in our ZF Control software and it always helps to keep the registration intact. Perhaps something like that must be found in your scanner software. Also did you "skip the registration" while indexing the fls files?
Peyman
mikajahkola
4
Country: Finland
This seems to happen occasionally with Recap v.23.0.
We use Recap to register Faro scans (fls). After registration everything else looks ok but the key plan is shifted and/or rotated.
As a workaround I have exported the registered point cloud as e57 (option "complete"), then created a new rcp project and imported the e57 with option "skip registration". Now the key plan should be right.
