Scan2bim scan2revit Waterslide
Please feel free to any show off any projects you may have done
GCFdesign
Full Name: Gary Fellows
Company Details: GCF Design Limited
Has thanked: 28 times
Been thanked: 12 times
Post by GCFdesign »
As part of a Scan2bim scan2revit exercise to model a leisure centre, today l created a mesh model of the waterslide.
Gary Fellows
Director
GCF Design Limited
https://gcfdesign.wixsite.com/gcfdesign
GCFdesign
Re: Scan2bim scan2revit Waterslide
Post by GCFdesign »
Waterslide data...
Gary Fellows
Director
GCF Design Limited
melshy
I have made 90-100 posts
Full Name: Duy Nguyen
Country: Vietnam
Skype Name: duy_bz
Has thanked: 6 times
Post by melshy »
What will you do with the mesh object?
GCFdesign
Post by GCFdesign »
The mesh model is within the leisure centre as-built Revit model, in context with everything else.
Gary Fellows
Director
GCF Design Limited
melshy
Country: Vietnam
Skype Name: duy_bz
Post by melshy »
SO you will render image or path video by revit ( enscape )
GCFdesign
Post by GCFdesign »
melshy wrote: Tue Oct 29, 2019 7:37 am SO you will render image or path video by revit ( enscape )
Rendered image was generated within Revit. Usually l perform my renders using Lumion Pro.
Gary Fellows
Director
GCF Design Limited
melshy
Country: Vietnam
Skype Name: duy_bz
Post by melshy »
i understand :) but the mesh objects will make Revit file heavy. if it was me then I would convert it to 3D solid by Inventor or X design :)
GCFdesign
Post by GCFdesign »
It is not heavy. Lightweight meshes.
Gary Fellows
Director
GCF Design Limited
Mike Annear
Full Name: Mike Annear
Company Details: Mike Annear
Has thanked: 14 times
Been thanked: 47 times
Post by Mike Annear »
GCFdesign wrote: Wed Oct 30, 2019 9:10 am Lightweight meshes.
Now there are two words you don't often see together :)
It is pretty simple to model in Rhino 3D, PM me if you need it done,
Mike.
Mike Annear
www.mikeannear.com
QLD, Australia.
Jamesrye
Full Name: James Rye
Been thanked: 11 times
Post by Jamesrye »
+1 for Rhino3d. It's excellent.
Return to “Show off Past Projects”
