Hello All,
So I have been using Cyclone 9.1.6 to perform my scan registrations for awhile now. We are trying to transition over to Trimble however though we will still be using the Leica Scanner. So, my question is:
How can I import my scan files into TBC if the data from the scanner is saved as a .bin? Will TBC recognize this format or do I need a converter? Thank you for the help!
Phill
How to import Leica .bin into TBC
- phillhend
- I have made 60-70 posts
- Full Name: Phillip Hendrickson
- Company Details: PennDot Photogrammetry and Surveys
- Company Position Title: Terrestrial LiDaR Technician
- pburrows145
- Full Name: Paul Burrows
- Has thanked: 109 times
- Been thanked: 123 times
Re: How to import Leica .bin into TBC
Any ascii format should work - perhaps try E57 export from Cyclone?
Leica *.bin files will not go directly into Trimble software.
Registration is SO much easier in Cyclone however... why the transition? Seems an odd move.
- phillhend
I couldn't agree more about Cyclone being easier to use for registration. We are really trying to see if we can use TBC predominantly in the lab, I am arguing that as long as we have a Leica scanner, Cyclone will be the preferred registration software. In terms of the back end of things however, TBC's Auto-classify tool seems to be great for data extraction. I am still working out the most efficient workflow on the post processing. I will continue to use Cyclone, but any thoughts or advice?
- Full Name: Jared
- Skype Name: jaredmatthews
- Has thanked: 5 times
- Been thanked: 13 times
As Mr Burrows has suggested, I would say do tour registration in Cyclone, kick out an e57 (or pts, ptx, xyz - either of these can be ready in by Realworks) then import that into Realworks to perform your auto-classification.
Quite a process, but probably easier than trying to convert .bin into a readable format for RW to register.
Sent from my E6653 using Tapatalk
