Is there a way to run the "unfurl" command - but along a spline (or series of straights?)
I have a fence line I need to elevate over a few hundred meters - but is "curved" so no simple elevation alignment - and ideally need to keep its accurate length.
Tim
Unfurl Scan Data Along A Spline
- NOVAMECH
- Full Name: Nick Bush
- Company Details: NOVAMECH
- Country: New Zealand
- Skype Name: novamech5
- Has thanked: 9 times
- Been thanked: 9 times
Re: Unfurl Scan Data Along A Spline
Contact - the guy at cloud compare. He updated or added Unfurl of a CONE for me some months ago. That guy is a gifted in ways us mere morals can only dream of.
- Full Name: James Rye
- Has thanked: 28 times
- Been thanked: 69 times
Tim,
I think you might be able to do this using Rhino's "smash" and "unroll" commands. You can download a trial which works for 25 days or so.
I used the software to unroll/unfurl tank shells for deformation analysis before moving to alternate software.
https://www.youtube.com/watch?v=ebzhFhXjSpI
youtu.be/ebzhFhXjSpI
- Phill
- Full Name: Phillip Nixon
- Company Details: SKM
- Has thanked: 7 times
- Been thanked: 45 times
Tim
Here is something I wrote this morning. Hopefully you have Autocad. I used Autocad so you can define the polyline (and cause I'm too lazy to write a intersection function in a different programming language), but you don't need the cloud in Autocad. It reads and writes to a unifed pts file (only). You need to give it a polyline for the alignment (not a 3d polyline), and it needs to be all straights (no curves).
Completely untested so have a good look at the results, I fed it some example data and it looked like it got it right. Give it a wurl and let me know if it works.
Phill
Phill
- TimBeach
- Full Name: Timothy Beach
- Company Details: Hollis
- Company Position Title: Senior Associate - Measured Surveys
- Has thanked: 4 times
- Been thanked: 4 times
Phil - fantastic! Thank you very much for taking your time to do that!
I'll give it a test and let you know where it gets to!!
