PointCloud Free Edition (FE).
Discuss all FARO As-Built related issues here
JulieEdwards
Full Name: Julie Edwards
Company Details: Latimer CAD Limited
Skype Name: julie-latimer-cad
Post by JulieEdwards » Tue Jun 01, 2010 10:40 am
NEW!
AutoCAD 2011 now contains a native point cloud engine which is powerful enough to handle up to 2 billion points of scan data. Currently, AutoCAD only supports a few data formats for import to .PCG.
kubit is happy to fill this gap by providing many more import options with our new PointCloud Free Edition. Users can now take advantage of the powerful AutoCAD .PCG engine and import the data from their laser scanner directly into AutoCAD.
Download http://download.kubit.de/english/exe/Po ... /setup.exe
The Free Edition may be upgraded to either PointCloud Basic or PointCloud Pro to enable the full Cloud management and modelling tools.
J
DanCutler
Full Name: Dan Cutler
Company Details: Bentley Systems
Skype Name: dan_pointools
Re: PointCloud Free Edition (FE).
Post by DanCutler » Tue Jun 01, 2010 11:18 am
Hi Julie,
can you list the compatible formats please?
:D
JulieEdwards
Post by JulieEdwards » Wed Jun 02, 2010 10:53 am
Dan
Formats supported;
- ASCII (RGB, Intensity or Grey encoded). User customisable format, includes PTS
- PTZ
- ScanPro Projects
Faro and LAS projects are of course supported within AutoCAD 2011 itself.
J
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Post by Phil Marsh » Tue Jun 15, 2010 8:09 am
Julie,
I get an error when I try to run the appload (PCLoader.ARX). Do you know why?
scott.diaz
Full Name: Scott Diaz
Company Position Title: Business Development
Post by scott.diaz » Wed Jun 16, 2010 9:54 pm
Hi Phil,
Make sure that during the install you have chosen AutoCAD 2011 from the list and for 32 or 64 bit as appropriate. For example, if you loaded a 32 bit version by mistake and run a 64 or you chose to install for a previous CAD version then it may give you this error. Perhaps uninstall and try again. Let me know if the error comes up again. It would be unusual but i am sure we can figure it out together.
Scott
Phil Marsh
Post by Phil Marsh » Thu Jun 17, 2010 8:56 pm
scott.diaz wrote:Make sure that during the install you have chosen AutoCAD 2011 from the list
Do I still need to choose this option even if I have Autocad 2009 (Architecture).
I have a 64bit PC so I choose that option, I'll try it agian at work tomorrow.
scott.diaz
Post by scott.diaz » Fri Jun 18, 2010 8:41 pm
Hi Phil.
No if you are running 64 bit 2009 AutoCAD Architecture then you can choose the option to install for "2008-2009 64 bit" setup. If the PCloader.arx is still not loading afterward than it is most likely a service pack issue with your AutoCAD version. You can update to the latest service pack by going to http://usa.autodesk.com/adsk/servlet/ps ... 8#section3.
The only problem with loading PC6 FreeEdition with AutoCAD 2009 is that it has zero features to utilize. The only advantage of the FreeEdition is to use some additional imports for converting data to PCG format in AutoCAD 2011. This is to temporarily fill the gap since Autodesk has only provided FLS/FWS/LAS imports to all 2011 releases besides Map/Civil. I would recommend downloading 2011 if you want to take advantage of the PointCloud FreeEdition.
Hope this helps,
Scott
omega
Full Name: David Keohane
Company Details: Omega Geomatics
Company Position Title: Partner
Country: England
Post by omega » Fri Jul 02, 2010 9:37 am
Julie/Any Kubit Pointcloud users,
I'm trying to convert a .ptc to .pcg which according to the blurb on their website and what has been mentioned here is available in the free mode. However, its isn't allowing me to do so.
Any ideas?
David
scott.diaz
Post by scott.diaz » Mon Jul 05, 2010 4:43 pm
Hi David,
kubit has not opened the PTC format in the FreeEdition. This is because many people are still on previous versions of kubit software that utilize only this file format and not the new PCG/ISD formats in 2011 AutoCAD. I am not sure when kubit will completely open this conversion option but will check it out.
PTC to PCG conversion is available in the full version of the software. If you need us to help you get on a trial then please just let us know. You will be able to perform the conversion this way.
FreeEdition is simply to help those on 2011 take advantage of the PCG format if they do not have the native FLS/FWS/LAS formats or access to Civil/Map 2011 which offer additional imports. kubit FreeEdition offers additional imports for ASCII/PTS, PTZ, and .RSP. kubit is also providing imports in their free PlanarView program if you would like to view PTZ, PTX or FLS files in a panoramic view. Just another option for you.
Hope this helps,
Scott
Ixtlan
Full Name: Joseph Severn
Company Details: 4D Max
Company Position Title: Scan Monkey
Post by Ixtlan » Wed Apr 20, 2011 9:54 am
Hi Julie
I'm using the free version of PointCloud. When I try to import a PTS file using the ASCII import function it automatically converts it into a PTC file which the free version is then unable to import. Is it possible for me to import PTS files with the free version?
Many thanks.
J.
Return to “FARO As-Built”
