Faro Scene E57 export settings (rows and columns)
fobos8
Forum Supporter
Forum Supporter
Full Name: Andrew
Company Details: Medina Surveys
Country: Uk
Has thanked: 14 times
Been thanked: 10 times
Re: Faro Scene E57 export settings (rows and columns)
Post by fobos8 »
3DForensics wrote: Tue Sep 15, 2020 10:14 pm You can get a decimated point cloud, but not the same thing. You are removing points by adjusting rows and columns as opposed to keeping a minimum point spacing when choosing the space variable.
Imagine the scanner being far away from a surface. The point spacing is already large and you would want to keep those points. If you remove them from rows and columns, the scan becomes even less dense. If you adjust the point density to 2mm, then the points closest to the scanner get decimated and the points farther away are kept in place.
Eugene
Thanks Eugene for the clear explanation. What you write make good sense.
Return to “FARO SCENE”
