Editing scanner images
MarkL
12
Full Name: Mark Lupton
Company Details: Wolverton
Skype Name: [email protected]
Post by MarkL »
I've had a look around the forum and don't see an answer to my question. The link below seems to, but my current version of Scene doesn't have the same options.
viewtopic.php?t=4083
I'm trying to export the scanner images, batch edit them and re-import them to colorize the scans. I can export/edit ok, but I don't see the option to re-import them. I can replace images individually, which takes too long. I can also replace the color overlay, but that doesn't colorize the scans. I'm sure I'm missing something simple, but can anyone make a suggestion?
Raimund58
Full Name: Raimund Klink
Company Details: IHM engineering GmbH
Company Position Title: 3d scanning guy
Has thanked: 193 times
Been thanked: 25 times
Re: Editing scanner images
Post by Raimund58 »
What version of Scene are you using?
This can maybe help you: https://knowledge.faro.com/Software/FAR ... s_in_SCENE
\o/
blazaj
14
Full Name: Jiri Blazek
Country: Czech Republic
Has thanked: 45 times
Been thanked: 18 times
Post by blazaj »
RMB menu on a scan go to Export color overlay. After you adjust the image use Replace color overlay to import it back to Scene.
Hope this helps
Jiri
MarkL
12
Post by MarkL »
I'm missing the highlighted command line. That's what I need to re-import my edited images. The color overlay doesn't colorize the points, it's just made from the individual images taken by the scanner. I'm using 7.1.1.81 and also the newest version, it's missing from both.
DavidL
I have made 90-100 posts
8
Full Name: David Lander
Company Details: Thames Valley Police Authority
Company Position Title: Crime Scene Surveyor
Has thanked: 19 times
Post by DavidL »
Replace Colour Overlay method as described by blazaj is what I've always done.
Sent from my SM-G950F using Tapatalk
MarkL
12
Post by MarkL »
DavidL wrote: Tue Nov 06, 2018 11:29 pm Replace Colour Overlay method as described by blazaj is what I've always done.
This method recolorizes the scan points? It didn’t seem to work when I tried it.
Raimund58
Post by Raimund58 »
For me it is working... Operations->Color/Pictures->Replace Color Overlay...
\o/
DavidL
8
Post by DavidL »
The individual images the scanner takes are full resolution, when you click 'apply pictures' the software stitches and matches to the scan resolution. The overlay is what does the colouring as it's resolution matches the scan, hence the name overlay.
MarkL
12
Post by MarkL »
I got it to work. not sure why it didn't before, might've been a naming thing with the bitmap. Thanks all.
INV_Scanning
4
Full Name: Sebastian Winkler
Company Details: INVERS Industrievermessung und Systeme
Has thanked: 5 times
Been thanked: 6 times
Post by INV_Scanning »
Hi folks,
this looks like the closest topic to my current problem. We have to modify colour overlay to eliminate faces in panorama pictures.
The 315 scans of the project were taken with 3x HDR. After reimporting the manipulated images and applying them to the scan data, an error appears when saving (Code 30, so some data wasn´t found anymore, looks like the three HDR panoramas). With ignoring the error messages for each scan, the project also saves as normal. No real problems until this point.
When I the try to get my sub projects to Recap, the files are detected as corrupt and will not index.
We already found a workaround by using the direct RCP-Export of SCENE. To my eyes it is a really bulky way around and there must be another better way.
Anybody with similiar problems and maybe a better workaround?
Thanks in advance ;)!
Sebastian
Return to “FARO SCENE”
